I vote we have a crazy horse night. Anyone else in?
[rant]
dont get me wrong here... and this may end in a flame session.....
firstly, i truly enjoy looking at naked women... its great :(
I dont like strip clubs tho,they are fkn tacky and over priced. look and no touch is $hit house....i can honestly say that i dont find strippers sexy. There is no thrill of the chase , just the thrill of handing over cash to have a twat waived in ur face. Teh strippers are all so detached from what they are doing, and there are so many lurkers.
[/rant]
Probably could've started a new thread with this but its not car related, so here goes.
Even biker funerals will be illegal gatherings under new laws enforced by Mr Rann as of next month....how on earth will he be able to enforce the new laws.
There are only about 30 Star Force in the state with 50 total on the books....they'll become full time babysitters along with Avatar....forget about other crime out there!!
Jokers Illegal Funeral
They can't even associate with their Uncles & Aunties more than 6 times a year.........won't work Mr Rann!
well i would have liked them to enforce that law when a mate died
David Driscol there was about 100 + bikes and about 200 cars they closed off pt road so we could all get out and follow the presesion there were members from all over australia
so good luck with that!
well i took off tonight in the wet and u know when ya hit high revs the car sorta bounces... well i changed to second and just died! started to sound like a wrx!!!!! and smells like fireworks!!! wat could i have done! i cannot even drive it anymore!its like bopbopbopbopbopbop
fuel pump is still buzzing!
it actually happened round the corner from my house and i coasted home!
naughty boy lol heard the whole thing unravel
any ideas? i have herd pump?? seems to buzz louder and sound like its choking??
probably just blew an intercooler hose off.....is it running real rich and idling like a pig.
You may have kacked a turbo too
    • Yeah it is always worth testing and balancing actuators out of the box, just set the pressure regulator on a compressor very low (eg 5 psi) and increase it slowly to see when they both move.....unfortunately while you may be able to adjust the length of the actuator rod to minimise any difference, the actual pressure they move from is not adjustable so you need a well matched pair. And yes, the VCAM is probably contributing; the earlier in the rev range they come on boost and the slower the revs build (I think your demo was in 5th), the more you notice it.  Driving at WOT through 1st, 2nd, 3rd etc you will probably never hear it as any shuffling starts and is over super quickly
    • oh they were with that motor, you need to remove the engine to change the spark plugs (don't have to, but it does make it easier)
    • I certainly fall into the annoyed camp, but glad to hear that if it's happening at low boost then I'm not likely going to blow a turbo and end up with metal shards in my oil. Just feels like it prevents me from really driving it without hesitation and "peak" performance. Wonder if it's the VCAM, it did an impressive job of shifting the torque curve and faster spool, but maybe now it's "too fast" and there's too much air for how open the throttle is.  Based on some other threads, will also do some reading on synchronizing the actuators. They are the default actuators that come on the Garrett's and I would think they would be set the same coming from the factory, but if the turbos don't actually work exactly the same way at the same time as previously mentioned, it would be worth making sure the actuators are actuating together properly
    • I went down this rabbit hole before, ended up sourcing a motor from the UK (I'm in Japan) which also didn't function correctly. With the original motor, I disassembled it and reassembled it and it works somewhat, sometimes. What I could deduce from all my screwing around is that there is calibration of the gears on the inside of the motor and two ramps on the main gear which activate switches that operate the motor and move the sunroof either to retract into the roof or tilt. Where I got stuck was that, it seemed in my case that one or both of the switches that are activated by the ramp on the gear did not always activate and thus the motor did not move, causing it to sometimes not retract or tilt (apologies, I've forgotten which way it didn't work.).  Of course this part is discontinued at Nissan now, it's the same part in the S15 but no other models. I also contacted the manufacturer of the component for schematics - forgot the name, they're based in Gifu - but they declined to share the information due to being bound by an NDA, sadly. Looking through my pictures now, it seems I last had a crack at this in 2022. See, I so kindly wrote "open" and "close" next to the switches. If you figure it out, please do tell me. Those little switches, with the red buttons may need to be replaced.
