congrats on the sale of the car flick, does that mean you guys will be repping shepparton in the falcoooon?
on another note ive got a business id like to plug for their awesome service. took my radiator to get pressure tested and flushed today, went to Parkside Radiators (also trade as Edwardstown Radiators) at Melrose Park. The guy tested it then and there, showed me where the 2 leaks were, explained what he would need to do to fix, told me not to be too fussed about a couple of bent fins (from fan contact at some point) as it hasnt damaged it. I told him it wasnt a rush to fix it, and that id pick it up same time next week, but he still offered to fix it tonight and have it ready for pickup tomorrow. The clincher: For the pressure test, re-soldering around the top tank outlet, fixing the leak in one of the tubes, replacing the "tap" (which id broken off ages ago and let it weep a lil bit), and giving it a reverse flush, its costing me a grand total of $70
+1 to them
Parkside Radiators
7 Manfull St Melrose Park
lol ryan
nah, need a proper cat
617 is far better than the current 200cfm item :D
definately know, by changing this, easy 200kw tune
last night had the attessa system working , lol
boosts well, bit soft in first, but second and third pull hard
IMO around 200ish atw is enough for the street, always been my goal.
sleeper wagon, nothing outstanding to look at (bar being a Stagea !), but streeter-eater deap down
:banana:
    • Not really, but the heater box is pretty simple mechanically....if the door is one way the air bypasses the heater core and if it is the other way it goes through it for warm air.  If you are sure the actuator you moved manually is for the heater mix (there would also be one for output air direction) then I'd take the heater box out and see what is happening (you'll have to regass and re-coolant the systems afterwards) BTW pp724 onwards from the GTR workshop manual cover the system in good detail, it is probably worth checking. I think the IAT sensor might be a problem electrically for getting cold (if you got 24 error code not -24 it thinks the incoming air is -50c) and it covers how to test the sensor (although most likely it is either not plugged in or a wire is damaged)
    • Use the GKTech subframe bush and bring your subframe 10mm closer to the chassis. You'll need to fix an exhaust hanger to suit. One of the best mods I've done.
    • You'd really have to pull it apart further to know, it least you can be confident that the one heading to the back is not connected any more. There was once a ground on the shifter seal mount too, your head unit issue could be that simple
    • Perfect, I'll get to it this winter then at the same time as I weld on my anti squat kit.
    • Alright so my 32 only has one temperature no matter what degree you set it to. I’ve tried disconnecting the servo motor arm and moving it either direction and got no change. I’ve fixed the leak in my AC and re charged it and with it on and clutch engaged it still blows hot even though the low pressure pipe going to the firewall is ice cold. Both heater core hoses are hot while running as well. Diagnostic code showed 24 for intake air temperature sensor. Anybody got any ideas?
