congrats on the sale of the car flick, does that mean you guys will be repping shepparton in the falcoooon?
on another note ive got a business id like to plug for their awesome service. took my radiator to get pressure tested and flushed today, went to Parkside Radiators (also trade as Edwardstown Radiators) at Melrose Park. The guy tested it then and there, showed me where the 2 leaks were, explained what he would need to do to fix, told me not to be too fussed about a couple of bent fins (from fan contact at some point) as it hasnt damaged it. I told him it wasnt a rush to fix it, and that id pick it up same time next week, but he still offered to fix it tonight and have it ready for pickup tomorrow. The clincher: For the pressure test, re-soldering around the top tank outlet, fixing the leak in one of the tubes, replacing the "tap" (which id broken off ages ago and let it weep a lil bit), and giving it a reverse flush, its costing me a grand total of $70
+1 to them
Parkside Radiators
7 Manfull St Melrose Park
lol ryan
nah, need a proper cat
617 is far better than the current 200cfm item :D
definately know, by changing this, easy 200kw tune
last night had the attessa system working , lol
boosts well, bit soft in first, but second and third pull hard
IMO around 200ish atw is enough for the street, always been my goal.
sleeper wagon, nothing outstanding to look at (bar being a Stagea !), but streeter-eater deap down
:banana:
    • A few suggestions: Do you have the option of retarding your exhaust cam gear to bring the power band over to the left? VCT would be turned off after you make peak torque, you see the power/torque will decay faster with it left on all the way to the limiter Once VCT is turned off, you'll find the motor will take a bit more timing being ramped in Send its mum, more boost! Of course, depends on your exhaust pressure.
    • Tow a boat... people won't know wtf is going on 🤣
    • I was back on the dyno again yesterday after completely revamping my methanol injection system. I was making 440kw at 19psi. Great, this is more then I was making last summer with my old meth system at that pressure, and I figured it would be smooth sailing up to 30+psi. We continued increasing from there and by 25psi, I had only hit 455kw. Dyno sadly lost utility power at this point and I left. We seemed to be on course to hit the same power wall as last summer (477kw@27psi). This is a built RB25 S1 stroked to a 2.8. Built and ported head with Kelford 272/262 cams. Precision 6466 Turbo. Tuner last year believed the power wall is a mix of RPM limitations (Hydro lifters/Limit set at 7600RPM) and fueling. With my new meth system, we're seeing zero knock now but it still won't go up.  What else can I do at this point? Here's my train of thought.  - It's clear from the dyno graph that I would easily make power to 8500+RPM but I'm limited to 7600RPM. I could risk increasing my limiter, but hydro lifters have me worried. What are my options here besides going NEO head or solid lifter conversion? I'm rocking a 1.05AR turbine on my 6466. Would dropping down to a .84 help shift that power down in anyway? - We're only seeing roughly a 30kw difference at the top end with VCT on or off. Is this normal? I want to confirm VCT is working properly. - Should I look into other cam options?  - Should I just keep increasing boost and see if she wakes up later on? I would expect to hit 600rwkw around 35psi with my 6466.
    • First thought is to use a ram mount (to hold the ipad) + windscreen suction mount. The arms on the ram mount can be as long as you like, should be able to position the ipad pretty well with that setup.
