Well done on the rims! Got a phone call from my missus this morning, some bitch decided to cut into her lane, she swirved to not get hit and ended up getting some gutter rash on my BuddyClub QF's :blush:
Not terrible but bad enough, looks like they will have to go in to get the lip re-done but nothing major
dunno Adrian - cant be that hard though we can take a look one day
Spewn Craig - have you tried taking the dash apart and seeing if wiggling it will fix it? -
sigh Luke /hatesFPD
na, will have a look over the weekend...might just buy a set of white, kinda over the blue.
good thing is, i can do it myself this time
HELP: running stock suspension and to my knowledge stock diff and so on and so forth. Yes my hicas are still connected and im getting a lock bar but im thinking diff's on its way out. How do u tell???? I just took of at lights sensibly of course and it shuttered that hard it knocked it out of gear!
Help Please I offer hugs and kisses
lol no offence ladies but sometimes your more trouble than your worth :rofl:
my car never complains we've been out too long :) or aren't you going to wash me in the morning
you can plat there hair :)
will agree to, friends with benefits FTW
    • You're already well into "gearbox is a consumable" territory there. A billet plate will either make it (effectively) 1% stronbger or make it last one more pass. At some point you'll probably tear 3rd gear into small chunks and regret all the life decisions that came before it.
    • ..and forum.r31skylineclub has been down all week....anyone know why?
    • I thought it could be an issue because the standard plate was flexing when stressed. Maybe the original gear set will hold a bit better without flex? Last time on the dyno it made around 670nm at the hubs. Now it have bigger turbo and better intake but have not been on a dyno yet. The car is being used from family trips to drag race events. So the shifts can be a little violent. It is grinding if I shift to fast so was thinking I should overhaul it soon.
    • From the factory on RB26s there's a fitting on the intake manifold collector/"plenum" that provides pre-throttle boost signal. That's how they did it back in the day, I figure it's fine to replicate it.
    • I would be surprised if that wasn't the issue. It's probably telling you, that even if you remove the plastic liner, you may have some other clearance issues that may occur too in some scenarios. IE, tyre to guard. It looks like someone has already rolled the lip, but you may still have issues in the future IE, turning and hitting a bump etc. The fact it changes how bad it makes the noise when you are going backward vs forward is highly indicative that it's the tyre rubbing. They do make a terrible sound, even if you're only pushing a project car that has a liner hanging down on a tyre!   Has the car been lowered? If it has been, what is the measurement from the centre of the wheel hub to the lip of the guard straight up?
