Well done on the rims! Got a phone call from my missus this morning, some bitch decided to cut into her lane, she swirved to not get hit and ended up getting some gutter rash on my BuddyClub QF's :blush:
Not terrible but bad enough, looks like they will have to go in to get the lip re-done but nothing major
dunno Adrian - cant be that hard though we can take a look one day
Spewn Craig - have you tried taking the dash apart and seeing if wiggling it will fix it? -
sigh Luke /hatesFPD
na, will have a look over the weekend...might just buy a set of white, kinda over the blue.
good thing is, i can do it myself this time
HELP: running stock suspension and to my knowledge stock diff and so on and so forth. Yes my hicas are still connected and im getting a lock bar but im thinking diff's on its way out. How do u tell???? I just took of at lights sensibly of course and it shuttered that hard it knocked it out of gear!
Help Please I offer hugs and kisses
lol no offence ladies but sometimes your more trouble than your worth :rofl:
my car never complains we've been out too long :) or aren't you going to wash me in the morning
you can plat there hair :)
will agree to, friends with benefits FTW
    • Possibly avoid using a Cometic one unless the deck/head surface are perfectly flat. I did have a look just then and forgiving gaskets such as Tomei or Nitto don't exist for the FJ20, however the Bar-Tek or Kameari ones look good and might do the trick.
    • Because pipe threads for pipe things. M threads for bolt things. Throw some teflon sealant onto it and dust your hands off knowing you did the right thing, instead of going twice around the block to achieve a result using the wrong things. Of course, all of these solutions are ignoring the fact that the minimum thread pitch we're talking about here is 1.25mm, with the 1/4" in NPT or BPS being out around 1.4mm. You will need to know that the boss you're tapping has enough thickness for at least a few threads. That's one of the reasons that 1/8" is commonly used - because the pitch is <1mm. And why would you look to use 1/4" NPT in a BSP country anyway? Ugh.
    • Just throwing around ideas, does it need to be in the compressor cover? Why not the hot side piping?
    • 1/8NPT drill size = 8.7mm. Since the hole got messed up by me, it’s probably around 9mm.    So 1/4” NPT would be next step. A drill size of around 11mm would be preferred there which is not way of my M12 (drill 10.5mm and tap M12 threads)
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
