I herd that a new law is comming in so you can run 19s or 20s on a skyline so will this mean the clearance from center of the wheel to guard will change??????
Its always been 2 inches above what came on the car stock. So for a '32 gtr, max is 18", for a 33 gtr, 19" for a '34 gtr, 20".... whether or not the tyre/rim is suitable for your setup, I guess that depends on the car in question but from what I understand, the 18" is the most I can put on my GTR. Which suits me fine cause I think the r34 gtr rims are pimp. So if any of u guys with 34gtrs get 20's, I'll take yr old rims >:(
-D
yeah it surprising hoew easy it is once you know how, i still gotta pull mine apart ans see why one has stopped working.
meh, ill add it to the 50 other things to do.
Edited by craig R33
ha ha, someone just offered me 600 for my rims my reply was.......ROFLMO.......thats all i wrote.
god, next they will want them for free.
Yeah, everyone wants something for nothing!
I had some the sphincter of the universe offer me $500 for my GSXR race bike which I'm selling for $5000 (bargain as is). I simply replied: "Come back when mommy raises your allowance."
Tell him "Sure, I'm desperate. I'll take the $630." Then give him an address of a biker club. :(
Thats a popular response of mine too. They won't be so scabby next time.
ok i took my coilpack cover off....
started the car waited 20mins or so to hit full operating temp...
nothing...
so i drove it and still NOTHING
so i have come to the conclusion that it may be getting hot under the cover at full opp temp?
i guess i drive it with the cover off till my spitfires arrive.. is it ok to leave the cover off??
and i correct in saying that this was prob the problem?
cheers
i ran it like this on the street for 2 years (and still do on track)
its not a problem, just dont go high pressure spraying your engine bay
HELP: running stock suspension and to my knowledge stock diff and so on and so forth. Yes my hicas are still connected and im getting a lock bar but im thinking diff's on its way out. How do u tell???? I just took of at lights sensibly of course and it shuttered that hard it knocked it out of gear!
Help Please I offer hugs and kisses
Some1 any1???
    • I don't think the shuffle can damage the turbos. It only happens at low shaft speeds and loads. It's just annoying (to some people - others are tickled by the effect) and it quite possibly reduces spool performance a little bit.
    • Oh dear. The panel beating needs to be done before the filler work. Do you have a photo of the dent before you started? Hard enough to not flex and only hit the high spots?  What do you mean it was just temporary?
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
