$300 for resonator, $200 for fitting and the junBL's were from the forum here for $450 for the pair (but they originally came from exh tech anyhow)...
Probably gonna get custom dumps, a barrel muffler and a high flow cat from them once I get my new turbos...
-D
Oh no shit no shit. I might go down there and see what he can do for me :banana:. Thanks alot.
I just went and hade a look at this fairlane zj that i won on ebay the add said it was in perfect con,one owner,on gas a small amount of surface rust on the inside of the bottom of the doors(common in the Zj to Zl fairlanes) and runs like a dream. The doors didnt have surface rust they were rusted out and in every door the motor was running crap a million leaks and sounded like it was running on 5 cylinders the gas tank was out of date by 1 year and the guy hadent even change the car in to his name from first owner. He made me wast my time by driving 40mins with a shitload of crap add so i wasted his time by saying il be back in 20mins with the money lol
Does anyone know how to change the injector values on a Power FC, or can anyone do it for me, will pay cash. I have my new 700cc Sards sitting in my spare room, just begging to be put in.
how much did the sards cost ya? Did you get fitting collars or a new fuel rail, and if so how much she set u back?
-D
you don't Matty :) best way to send multiple PM's is to make your list in txt pad exact copies of people's user names then make your pm and add first name then send then hit back on your browser and change name and repeat till all people on the list have been done
i needa find someone to put my lowered springs in before then too!
any one know of a cheap place to do it?
i pick them up friday, so its install only
Craig, ill do it cheap for you and youll learn as we do it if you want!!! I have everything to do it.
Ive done this a few times, I did it on my own car, you have to work out latency etc...Ill work it out and get back to you what to change if you want.
    • Apologies for the long post, but needed somewhere to lay out the entire timeline of events and actions taken:   I've got an 89 GTR with a R34 RB in it. It's been running great all year, driven probably 500KM in the last month. It's not my daily driver, just a weekend fun car.    Build info: R34 RB26 - HKS 2.7 stroker kit, HKS adjustable cam gears, HKS turbo upgrades, Trust intercooler, R34 factory DENSO 440cc injectors, JUN chipped/tuned R32 ECU. All of this work was performed in Japan back in 2019.    Thursday 10/2/25 - It's a nice day and decided I'll drive it to work, I start it up in the garage and I notice it took a few extra cranks and sounded a bit funny. I figure maybe it was just because it was a pretty chilly morning. I pull it out into the driveway to warm up a bit before leaving. As I leave the driveway, it feels very off and sounds like a misfire. I pull it back in the garage to deal with after work and take the daily to work. I was able to diagnose it as a cylinder 5 misfire with the old spark plug test (unplugging each plug until a sound change with the engine running). I take off the whole ignition system, ignitor, plugs, spark. *Important note, it is still on the R32 ignition system with the separate ignitor system. I test each system with a multi-meter and nothing presents as a smoking gun. I put it all back together and it starts up no issue. I go ahead and order the PRP R35 ignition conversion kit. It should arrive today (10/13/25)   Friday 10/3/25 - Another nice day, car starts up great and drives great all day. Very pleased that everything seems to be OK   Sunday 10/5/25 - Decided I'll take it to play some golf, load up and drive to the course about 25 minutes away. Drives wonderful the whole way there, I pull in the parking lot and the engine completely comes to a stop. I do not recall if it sputtered at all, but just remember all of the sudden the engine was off. I roll it into a parking spot, try to crank it back on and nothing.  It'll crank and crank and not even try to start. End up getting it towed back to my house and push it up into the garage.    Items I have checked: Fuel in the tank Fuel Pump relay Fuel pump fuse  Spark Plugs & gap Coil packs Ignitor    I know the cylinders are getting fuel as the plugs smell like fuel after a start attempt. I tried spraying starter fluid into the manifold and cranking and not even a sputter.    I decided to do the live CAS test (removing the the CAS, ignition on and spinning the CAS stalk to see if the injectors pulse and spark is active). All of the injectors were pulsing and I have spark at the plug. The half-moon end of the CAS did seem very loose, I'm not sure how much play is supposed to be there, but it was more than I expected. There was no in/out play of the shaft, just the tip end that is pinned on had quite a bit of play.    CAS Play video   When I put the CAS back in, I stupidly did not re-time the engine. I know I need to do that tonight, however, I do not think it will start given it seemingly was not the issue. My plan is to do the PRP R35 coil kit and retime the engine at the same time.    I plan on ordering the Haltech Nexus Plug-in ECU once they are available again, but ideally would like to get this sorted before firing the parts cannon at it and potentially adding more variables.    Anything glaring that I am missing here, I'm a bit at a loss?
    • Get it on a dyno. Get something logging Consult. Run it up and find out what is causing it.
    • Looking for a plenum for rb25 de+t neo  Not looking to push much power maybe 300kw at the wheels, is there much difference in flow for Freddy “Greddy style” compared to original Greddy or options like Proflow or Otaku garage?    I won’t be porting the de Neo head for now as I think it’ll be fine 280-300rwkw but appreciate the help and any experiences anyone has between them and any advice. Thanks  Looking at this plenum for now below
    • engine wise almost no mods: stock ecu Greddy front mount intercooler Greddy forward facing intake w R33 TB stock fuel system, stock injectors, rail etc. Kakimoto racing hyper 3 inch exhaust system Apexi intake filter New NGK –R BCPRES (.8 gap) plugs
    • Nice one @Pac - looks like a fair few 1600's there!
