Anyone wanna sell me an R34 Power FC? I hear alot about modding them to suit your application, so rb26 being modded to suit rb25 neo. Whats the go?
Can't mod the rb26 pfc to suit the Neo as they are a different plug. Could possibly do it I suppose if you grab a 25 or 26 plug and then painstakingly swap each individual pin. :P
NEO engines have variable valve timing, so Im not quite sure that they will fit rb26's... I dont believe there were any rb26's released with VVT... will probably need a special ECU to do VVT.... possibly easier to just remap the stock ecu
-D
-D
Nah its not variable.. Its the same as the r33 but 'apparently' smoother in its transition; of which comes down to the solenoid mechanism its self.
You can use a simple $34 window rpm switch imported from the US from a mob that I know of. Its basically a NOS switch; switch on at x rpm then switch off at y rpm.
yea thats what i was gonna say lol
people usually use rpm switch when they use an rb20 remapped ecu on an rb25.
hrm news to me, i always thought they were some special type of comp controlled head ...
will know better next time :P
-D
On a totally unrelated topic, theres a"1993 GTR turbo skyline" in the paper for $10,000. im thinking its not a gtr, so i messaged him "hey mate, is the gtr still for sale?" i get back "yes". hmm, guess ur keen to sell then
    • Ok i will get those 310mm. I found one but on a different site. This is the description on those...is it ok? Technical parameters: - Axle: front. - Disc type: ventilated. - Number of holes: 5. - Disc diameter: 310mm. - Total height with center: 54mm. - Thickness (new/min.): 30/28mm. - Designed for brake calipers manufacturer: Sumitomo.
    • You Gregged a whole racetrack!?
    • Look for broken wire or bad connector at the motor. Might not be it, but is worth starting there, as it is easy.
    • Hi everyone, I’m having an issue with my R32 GT-R. Sometimes, when the car goes over a bump or experiences some vibration, the 4WD warning light comes on the dashboard. When I check the code from the control unit in the trunk, it shows Code 19 – ETS Motor. However, everything seems to be working fine — if I turn off the engine and restart the car, the light goes away and everything functions normally. Has anyone experienced this before? Where should I start troubleshooting this issue? Thanks in advance!
    • I'm back from the dyno - again! I went looking for someone who knew LS's and had a roller dyno, to see how it shaped up compared to everything else and confirm the powerband really is peaking where Mr Mamo says it should. TLDR: The dyno result I got this time definitely had the shape of how it feels on the road and finally 'makes sense'. Also we had a bit more time to play with timing on the dyno, it turns out the common practice in LS is to lower the timing around peak torque and restore it to max after. So given a car was on the dyno and mostly dialled in already, it was time for tweaking. Luis at APS is definitely knowledgable when it came to this and had overlays ready to go and was happy to share. If you map out your cylinder airmass you start seeing graphs that look a LOT like the engine's torque curve. The good thing also is if you map out your timing curve when you're avoiding knock... this curve very much looks like the inverse of the airmass curve. The result? Well it's another 10.7kw/14hp kw from where I drove it in at. Pretty much everywhere, too. As to how much this car actually makes in Hub Dyno numbers, American Dyno numbers, or Mainline dyno numbers, I say I don't know and it's gone up ~25kw since I started tinkering lol. It IS interesting how the shorter ratio gears I have aren't scaled right on this dyno - 6840RPM is 199KMH, not 175KMH. I have also seen other printouts here with cars with less mods at much higher "kmh" for their RPM due Commodores having 3.45's or longer (!) rear diff ratios maxing out 4th gear which is the 1:1 gear on the T56. Does this matter? No, not really. The real answer is go to the strip and see what it traps, but: I guess I should have gone last Sunday...
