I had a slight issue when I was running a 400fsb where it was rock solid in prime and memtest yet BF2 would still randomly drop to the desktop. Dropped it back to 333 with the same overclok and its now fine.
Thats a memory timing issue. Either the ram isnt rated at 400mhz / pc3200 or the latency timings are out of whack... I only ever had that with cheap ram. When I switched to corsair xtra low latency ddr I stopped having problems (and got a better whetstone too)
-D
what is it? besides a brand of jam ? ^
Theres your standard, baseline ram which is good for what its rated for.... but barely...
Such ram is made by Hynix, Legend.... then you have the really good stuff for overclockers and system tweakers, usually its made by Corsair or OCZ or Team Extreme.... not only can they deal with faster FSB's (for when you're overclocking the FSB) but they can also support more aggressive latency timings (which makes the system more responsive as opposed to FSB which is just how >fast< the memory transfers...)...
Will definately be buying corsair next time but that wont be for another year.... need new turbos first >:(
-D
My supervisor is off sick, so me and my mate are making her a computer out of cardboard. i even photocopied the keyboard and stuck it on some cardboard :( that will teach her for being sick.
If she has a cubicle, tape the entrance off and tip a few hundred litres of packing beans into it. Laughs ahoy
-D
I have seen a pic of that, unfortunately we don't have a cube farm here. I filled a guys draw with packing beans once, he wasn't overly happy.
the other thing u could do is use a screwdriver/ruler to pop the keys off her keyboard... then put them back on in random locations... it'll confuse the hell out of her muahahaha
-D
-D
Ha did that to my mate on friday, and he still hasn't noticed.... dick
-D
I had a mate try that one on me. Joke backfired because I can touch type and not look at the keyboard :D
He got immensely irritated that I wasn't taking the bait. :) It all started because I gave him shit about how he's an IT 'expert' yet he types with 2 fingers at about 15wpm.
Haha. Whenever anyone says they're an expert at anything IT related, you know theyre talking out their cornhole :)
Other thing is to replace the kb with one of those touchtype keyboards without the letters printed on them. Really screws with novices...
http://www.thinkgeek.com/computing/input/8396/ heh....
-D
hahaha sorry bud already have HID maybe you can take my lead and try a group buy yourself
steve wanna do a group buy for headlights? i wouldnt mind new ones as mine arent too bright!!
Mark - how'd you go with your computer
-D
The board is an EP35-DS3 so DDR2. :D
The ram is fine its DDR800 and not overclocked being at 800.
The chip simply has hit its fsb wall at 400; it doesn't like 400mhz; 380fsb is fine. I haven't bothered to find where exactly the fsb wall is.
In the past I've always gone corsair, OCZ etc.. Had a few bad DOA corsair sticks (back in the ddr2700 and 3200 days) touch wood no issues with OCZ.
These days there's no need to go for the top line stuff unless your really after the last poofteenth; 1066 gear can be picked up cheap these days. Run 1:1 - thats a 533fsb of which will easily net 4ghz and beyond; providing your chip doesn't hit its fsb wall before prior. Intels are fairly forgiving to higher latency (unlike AMD) due to their mem controller design.
Save a shit load and buy decent A-data or kingston; you really can't go wrong. Stress it with memtest looping test 5 and then 8; if its bad it will show so return it for another 2.
What K are yours Steve? I was going to go 8k but i dont know, i like the 10k. Its a toss up between those 2. Also where did you get them from, ive been looking on ebay, but dont want to comit to the buy haha.
get 6k man 8 and 10 will be too blue and you'll find your self getting pulled over
and also a common miss conception is the higher the k the brighter they are bit its quite the opposite
i got mine from a group buy in R31skylineclub
Alright. 6k it is. Im a member over on the R31skylineclub forums, so might go have a look. Thanks mate. Probly would have gone the 8, but yeh, probly best if i dont get pulled over.
    • Well, that's kinda the point. The calipers might interfere with the inside of the barrels 16" rims are only about 14" inside the barrels, which is ~350mm, and 334mm rotors only leave about 8mm outboard for the caliper before you get to 350, And.... that;s not gunna be enough. If the rims have a larger ID than that, you might sneak it in. I'd be putting a measuring stick inside the wheel and eyeballing the extra required for the caliper outboard of the rotor before committing to bolting it all on.
    • OK, so again it has been a bit of a break but it was around researching what had been done since I didn't have access to Neil's records and not everything is obvious without pulling stuff apart. Happily the guy who assembled the engine had kept reasonable records, so we now know the final spec is: Bottom end: Standard block and crank Ross 86.5mm forgies, 9:1 compression Spool forged rods Standard main bolts Oil pump Spool billet gears in standard housing Aeroflow extended and baffled sump Head Freshly rebuilt standard head with new 80lb valve springs Mild porting/port match Head oil feed restrictor VCT disabled Tighe 805C reground cams (255 duration, 8.93 lift)  Adjustable cam gears on inlet/exhaust Standard head bolts, gasket not confirmed but assumed MLS External 555cc Nismo injectors Z32 AFM Bosch 023 Intank fuel pump Garret 2871 (factory housings and manifold) Hypertune FFP plenum with standard throttle   Time to book in a trip to Unigroup
    • I forgot about my shiny new plates!
    • Well, apparently they do fit, however this wont be a problem if not because the car will be stationary while i do the suspension work. I was just going to use the 16's to roll the old girl around if I needed to. I just need to get the E90 back on the road first. Yes! I'm a believer! 🙌 So, I contacted them because the site kinda sucks and I was really confused about what I'd need. They put together a package for me and because I was spraying all the seat surfaces and not doing spot fixes I decided not to send them a headrest to colour match, I just used their colour on file (and it was spot on).  I got some heavy duty cleaner, 1L of colour, a small bottle of dye hardener and a small bottle of the dye top coat. I also got a spray gun as I needed a larger nozzle than the gun I had and it was only $40 extra. From memory the total was ~$450 ish. Its not cheap but the result is awesome. They did add repair bits and pieces to the quote originally and the cost came down significantly when I said I didn't need any repair products. I did it over a weekend. The only issues I had were my own; I forgot to mix the hardener into the dye two coats but I had enough dye for 2 more coats with the hardener. I also just used up all the dye because why not and i rushed the last coat which gave me some runs. Thankfully the runs are under the headrests. The gun pattern wasn't great, very round and would have been better if it was a line. It made it a little tricky to get consistent coverage and I think having done the extra coats probably helped conceal any coverage issues. I contacted them again a few months later so I could get our X5 done (who the f**k thought white leather was a good idea for a family car?!) and they said they had some training to do in Sydney and I could get a reduced rate on the leather fix in the X5 if I let them demo their product on our car. So I agreed. When I took Bec in the E39 to pick it up, I showed them the job I'd done in my car and they were all (students included) really impressed. Note that they said the runs I created could be fixed easily at the time with a brush or an air compressor gun. So, now with the two cars done I can absolutely recommend Colourlock.  I'll take pics of both interiors and create a new thread.
    • Power is fed to the ECU when the ignition switch is switched to IGN, at terminal 58. That same wire also connects to the ECCS relay to provide both the coil power and the contact side. When the ECU sees power at 58 it switches 16 to earth, which pulls the ECCS relay on, which feeds main power into the ECU and also to a bunch of other things. None of this is directly involved in the fuel pump - it just has to happen first. The ECU will pull terminal 18 to earth when it wants the fuel pump to run. This allows the fuel pump relay to pull in, which switches power on into the rest of the fuel pump control equipment. The fuel pump control regulator is controlled from terminal 104 on the ECU and is switched high or low depending on whether the ECU thinks the pump needs to run high or low. (I don't know which way around that is, and it really doesn't matter right now). The fuel pump control reg is really just a resistor that controls how the power through the pump goes to earth. Either straight to earth, or via the resistor. This part doesn't matter much to us today. The power to the fuel pump relay comes from one of the switched wires from the IGN switch and fusebox that is not shown off to the left of this page. That power runs the fuel pump relay coil and a number of other engine peripherals. Those peripherals don't really matter. All that matters is that there should be power available at the relay when the key is in the right position. At least - I think it's switched. If it's not switched, then power will be there all the time. Either way, if you don't have power there when you need it (ie, key on) then it won't work. The input-output switching side of the relay gains its power from a line similar (but not the same as) the one that feeds the ECU. SO I presume that is switched. Again, if there is not power there when you need it, then you have to look upstream. And... the upshot of all that? There is no "ground" at the fuel pump relay. Where you say: and say that pin 1 Black/Pink is ground, that is not true. The ECU trigger is AF73, is black/pink, and is the "ground". When the ECU says it is. The Blue/White wire is the "constant" 12V to power the relay's coil. And when I say "constant", I mean it may well only be on when the key is on. As I said above. So, when the ECU says not to be running the pump (which is any time after about 3s of switching on, with no crank signal or engine speed yet), then you should see 12V at both 1 and 2. Because the 12V will be all the way up to the ECU terminal 18, waiting to be switched to ground. When the ECU switches the fuel pump on, then AF73 should go to ~0V, having been switched to ground and the voltage drop now occurring over the relay coil. 3 & 5 are easy. 5 is the other "constant" 12V, that may or may not be constant but will very much want to be there when the key is on. Same as above. 3 goes to the pump. There should never be 12V visible at 3 unless the relay is pulled in. As to where the immobiliser might have been spliced into all this.... It will either have to be on wire AF70 or AF71, whichever is most accessible near the alarm. Given that all those wires run from the engine bay fusebox or the ECU, via the driver's area to the rear of the car, it could really be either. AF70 will be the same colour from the appropriate fuse all the way to the pump. If it has been cut and is dangling, you should be able to see that  in that area somewhere. Same with AF71.   You really should be able to force the pump to run. Just jump 12V onto AF72 and it should go. That will prove that the pump itself is willing to go along with you when you sort out the upstream. You really should be able to force the fuel pump relay on. Just short AF73 to earth when the key is on. If the pump runs, then the relay is fine, and all the power up to both inputs on the relay is fine. If it doesn't run (and given that you checked the relay itself actually works) then one or both of AF70 and AF71 are not bringing power to the game.
