^^ i would to.
but its good that they didnt go to far with things.
shows, if we do the right thing (behave) the police will start to realise that we are not the ''typical'' ''hoon'' import drivers
meh, im just a whore, never mind me
Edited by craig R33
its true craig and as kellie said i think..
we are an australian wide clud cruising all the time! we keep it sensible and if anyone messes up they will be reported...
and hence y kellie gives her name out as the organiser over the cruise! to show them we are dead set about keeping it safe and under control!
wow i think this is one of my few quality posts! hahaha
Know how you feel there Craig (sick as a dog part!) Good to hear you had a great cruise everyone, glad I didn't make it now, if I didn't get defected last weekend I sure as shit would have tonight :bunny:
Night all :P
Yeah, i was down arndale way. There was a holdup of some sort at the chemist down arndale and were millions of cop cars. Got pulled over by Hanson rd
by 2 old dudes in a police Toyota Landcruiser. Got done for spacers on the rear. Not happy about it since all i was doing was driving but yeah ..... Anyone
have a stock R32 steering wheel lying around??
Hanson Road is one of those areas thats generally swarming with cops anyway (and the areas around it). Our training centre is on Grand Junction Road (shares the same facility as the MFS training centre)....and when i used to drive the 31 to trade school id CONSTANTLY get followed (even in its more stocker form that it was over the years. Would usually get pulled over and asked why i was so far from home LOL
if ya have any trouble finding parts let me know, ive got some random stuff laying around that may help ya
yeh steve 4 more road traffic coppers came.. spoke to dan and jenkies and kel and searched cars!
was interesting!!
copper says "whos family car" hahaha
I'm so glad they didnt wanna check out the family car!! LOL
Pulled this yesterday, not bad for my lack of mods, running about 9psi i think.
Sounds about right. Little more boost will pick up 20-30rwkw but its the mid range that is worth while. Accelerates you to that peak power considerably quicker.
Bugger injectors and tune the sucker on E85 for 240rwkw on the std turbo. :D
Nothing wrong with E85. I'll be grabbing myself some larger injectors and retuning.
Haha yeah i have plenty of plans Cubes :D The dyno i had it on is made for commercial vehicle tuning, and apparently readouts are always a little bit less then everywhere else. Should be getting my power fc soon, so ill have the AFR tuned a bit better. Might look at injectors too.
    • When I said "wiring diagram", I meant the car's wiring diagram. You need to understand how and when 12V appears on certain wires/terminals, when 0V is allowed to appear on certain wires/terminals (which is the difference between supply side switching, and earth side switching), for the way that the car is supposed to work without the immobiliser. Then you start looking for those voltages in the appropriate places at the appropriate times (ie, relay terminals, ECU terminals, fuel pump terminals, at different ignition switch positions, and at times such as "immediately after switching to ON" and "say, 5-10s after switching to ON". You will find that you are not getting what you need when and where you need it, and because you understand what you need and when, from working through the wiring diagram, you can then likely work out why you're not getting it. And that will lead you to the mess that has been made of the associated wires around the immobiliser. But seriously, there is no way that we will be able to find or lead you to the fault from here. You will have to do it at the car, because it will be something f**ked up, and there are a near infinite number of ways for it to be f**ked up. The wiring diagram will give you wire colours and pin numbers and so you can do continuity testing and voltage/time probing and start to work out what is right and what is wrong. I can only close my eyes and imagine a rat's nest of wiring under the dash. You can actually see and touch it.
    • So I found this: https://www.efihardware.com/temperature-sensor-voltage-calculator I didn't know what the pullup resistor is. So I thought if I used my table of known values I could estimate it by putting a value into the pullup resistor, and this should line up with the voltages I had measured. Eventually I got this table out of it by using 210ohms as the pullup resistor. 180C 0.232V - Predicted 175C 0.254V - Predicted 170C 0.278V - Predicted 165C 0.305V - Predicted 160C 0.336V - Predicted 155C 0.369V - Predicted 150C 0.407V - Predicted 145C 0.448V - Predicted 140C 0.494V - Predicted 135C 0.545V - Predicted 130C 0.603V - Predicted 125C 0.668V - Predicted 120C 0.740V - Predicted 115C 0.817V - Predicted 110C 0.914V - Predicted 105C 1.023V - Predicted 100C 1.15V 90C 1.42V - Predicted 85C 1.59V 80C 1.74V 75C 1.94V 70C 2.10V 65C 2.33V 60C 2.56V 58C 2.68V 57C 2.70V 56C 2.74V 55C 2.78V 54C 2.80V 50C 2.98V 49C 3.06V 47C 3.18V 45C 3.23V 43C 3.36V 40C 3.51V 37C 3.67V 35C 3.75V 30C 4.00V As before, the formula in HPTuners is here: https://www.hptuners.com/documentation/files/VCM-Scanner/Content/vcm_scanner/defining_a_transform.htm?Highlight=defining a transform Specifically: In my case I used 50C and 150C, given the sensor is supposedly for that. Input 1 = 2.98V Output 1 = 50C Input 2 = 0.407V Output 2 = 150C (0.407-2.98) / (150-50) -2.573/100 = -0.02573 2.98/-0.02573 + 47.045 = 50 So the corresponding formula should be: (Input / -0.02573) + 47.045 = Output.   If someone can confirm my math it'd be great. Supposedly you can pick any two pairs of the data to make this formula.
    • Well this shows me the fuel pump relay is inside the base of the drivers A Pillar, and goes into the main power wire, and it connects to the ignition. The alarm is.... in the base of the drivers A Pillar. The issue is that I'm not getting 12v to the pump at ignition which tells me that relay isn't being triggered. AVS told me the immobiliser should be open until the ignition is active. So once ignition is active, the immobiliser relay should be telling that fuel pump relay to close which completes the circuit. But I'm not getting voltage at the relay in the rear triggered by the ECU, which leaves me back at the same assumption that that relay was never connected into the immobiliser. This is what I'm trying to verify, that my assumption is the most likely scenario and I'll go back to the alarm tech yet again that he needs to fix his work.      Here is the alarms wiring diagram, so my assumption is IM3A, IM3B, or both, aren't connected or improper. But this is all sealed up, with black wiring, and loomed
    • Ceste, jak se mas Marek...sorry I only have english keyboard. Are you a fan of Poland's greatest band ever?
