^^ i would to.
but its good that they didnt go to far with things.
shows, if we do the right thing (behave) the police will start to realise that we are not the ''typical'' ''hoon'' import drivers
meh, im just a whore, never mind me
Edited by craig R33
its true craig and as kellie said i think..
we are an australian wide clud cruising all the time! we keep it sensible and if anyone messes up they will be reported...
and hence y kellie gives her name out as the organiser over the cruise! to show them we are dead set about keeping it safe and under control!
wow i think this is one of my few quality posts! hahaha
Know how you feel there Craig (sick as a dog part!) Good to hear you had a great cruise everyone, glad I didn't make it now, if I didn't get defected last weekend I sure as shit would have tonight :bunny:
Night all :P
Yeah, i was down arndale way. There was a holdup of some sort at the chemist down arndale and were millions of cop cars. Got pulled over by Hanson rd
by 2 old dudes in a police Toyota Landcruiser. Got done for spacers on the rear. Not happy about it since all i was doing was driving but yeah ..... Anyone
have a stock R32 steering wheel lying around??
Hanson Road is one of those areas thats generally swarming with cops anyway (and the areas around it). Our training centre is on Grand Junction Road (shares the same facility as the MFS training centre)....and when i used to drive the 31 to trade school id CONSTANTLY get followed (even in its more stocker form that it was over the years. Would usually get pulled over and asked why i was so far from home LOL
if ya have any trouble finding parts let me know, ive got some random stuff laying around that may help ya
yeh steve 4 more road traffic coppers came.. spoke to dan and jenkies and kel and searched cars!
was interesting!!
copper says "whos family car" hahaha
I'm so glad they didnt wanna check out the family car!! LOL
Pulled this yesterday, not bad for my lack of mods, running about 9psi i think.
Sounds about right. Little more boost will pick up 20-30rwkw but its the mid range that is worth while. Accelerates you to that peak power considerably quicker.
Bugger injectors and tune the sucker on E85 for 240rwkw on the std turbo. :D
Nothing wrong with E85. I'll be grabbing myself some larger injectors and retuning.
Haha yeah i have plenty of plans Cubes :D The dyno i had it on is made for commercial vehicle tuning, and apparently readouts are always a little bit less then everywhere else. Should be getting my power fc soon, so ill have the AFR tuned a bit better. Might look at injectors too.
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
