yeah, imagine all the gunk and shit yu'd get on the iphone from having it next to your ear all the time. Im happy with my phone. If i had an iphone, and it broke/got stolen, then i lose sms, calls, gps and music, the 4 things i use the most, all in one device.
So, anyone wanna but an old school (original) iPod nano? ill even leave my electro/house songs on it :thumbsup:
Edited by Damo_R34
Mike, the beauty of the internet! I downloaded it via torrent. Trust me, was well worth the download. Episode number 11x04, here's the EXACT file name to help you all...
top.gear.s11e04.ws.pdtv.xvid-river
Don't get me started on the iPhone, overhyped piece of shit as far as I'm concerned, as is the case with many Apple products, people just buy them to "look cool" and pay a premium for that coolness
Edited by heslo
not sure but didn't someone on here with a rb25 in a red r32 ran 280kw with stock injectors? i think his name was simon or something
If it wasn't safe it would have popped by now being an unopened rb25, considering the workout that car gets from simon, Im sure simon wouldn't have done this if he didn't think it was safe. Jeff from The Speed Lab tuned it.
iPhone=marketing bullshit. waste of money. ill stick to my bulletproof nokia and my creative zen. no way i will infect my computer with iTunes bullshit.
MMM still loving my Sony Ericsson K750i.... does everything I want except change the channel on the TV hehe
-D
hey... looking at turbos for my rb25 when she arives!!
i have been looking through slouches GB and came across the 3071r and 2871r..
which would be the turbo to go for and wat housings would best suit! looking for response and 280ish even 300kw fo a later date!
http://www.skylinesaustralia.com/forums/Ga...86-t210306.html
cheers
what do people think of these? going with my new slotted rotors.
EDIT, stupis link wont work!
heres some of the desciption:
QFM (Queensland Friction Material) Brake Pads are AUSTRALIAN MADE & OWNED
They have serviced the Automotive Trade for over 17 Years
these brake pads are rated at 750 Deg C.
they are designed for extreme use from the Street to the Track
K750 brake pads will perform from dead cold to 750 Deg C.
If you want the ultimate in performance & everyday durability these are the pads for you.
Edited by craig R33
    • Lets say I wanted to buy this, specifically for this purpose. How do I actually perform the function. Can I still buy a Consult-1? Am I about to be burned by the fact my car is a 2000 model Series 2 R34 and thus will be some stupid other system? Do I just need this -> https://obd2australia.com.au/product/nissan-consult-14-pin-to-usb-ddl-diagnostic-interface-with-ftdi-ft232r-chip/ And with what software?
    • That's probably OK. That's a face to face compression joint between two surfaces with the clamping load provided by those bolts. So.... it's unlikely that the bolts will end up feeling that load in shear, unless the clamping surfaces are not large enough, bolts not got enough tension on them, etc etc to prevent the two faces from moving wrt each other. Which... I would hope the designers have considered, seeing as it's probably one of the most important things the upright has to do apart from resist collapsing in its own right. But yes, it would definitely be worth asking them what their safety factor on that part of the design was. I tend to think that the casting, being a casting, is not necessarily the strongest bit of material in the world. It's about an inch square, and when you think about the loads that are being put into it, you have to wonder what safety factor the Nissan boys (and every other OEM engineer who has designed all the millions of other uprights that look essentially the same) used to account for defective casting, aging, severe impacts on the wheel, etc etc.
    • Those bolts would be orders of magnitude stronger that cast aluminium though.  And its mainly clamping force, not shear they are dealing with?
    • Except all that twisting force that is breaking a cast piece, appears to be going through 4 bolts in the picture Johnny posted of the BryPar one...
    • The smart approach is to use the gearbox loom from the manual car. Makes it a lot easier - just plugs into the switches on the box and plugs into the main loom up near the fusebox. Then you only need to deal with bypassing the inhibit switch. The other approach requires you to use the wiring diagram to identify those wires by colour and location, perhaps even indulging in a little multimeter action to trace them end to end to make sure, and then.... you will have the answers you need. The R34 wiring diagram is available on-line (no, I do not have a link to it myself - I would have to do a search if I wasn't able to go to the copy I have at home).
