used a wire wheel tonnes of wet and dry sand paper, undercoat and some decent paint. colour was tungston i think.. commodore colour :P
all up two full days
just temporary till i get them all blasted back and powdercoated properly
Might get mine done in a light grey.
yeah Roo that why you dont show up to the auction at all send your man in your place and have a phone link with him :P muhahahaha
thats actually very good advice. Make sure you also tell the agent that if the vendors insist with the auction going ahead that your offer may not be there at the end if it gets passed thru for less.
Nah this is what he meant. Theres the hose which goes from the turbo to the actuator. He said that apparently this was not meant to be, but there was
meant to be a solenoid that went in between it from Nissan factory. At this stage he had already passed me so i wasnt going to argue much, but i mentioned
that i thought they only came out on later models like 33,34. Bleh i dunno lol >.>
Congrats Min! Hopefully get mine passed next week so I can get back to driving it again! :D
Thanks Luke, just pray you dont get one of the younger looking guys. They looked fairly tough. (As in following the book down to the line@!) I got a middle aged
bloke who happened to be in a happy mood. I guess i got lucky!
My new tie rod ends has arrived awesome :D anyone fitted these before? Should I fit them myself I'm not sure because getting the adjustment exactly dead-on on both side looks to be a pain or should I have some suspension place do it so they adjust it and get an alignment done aswell?
If you need a hand mate, ill help ya out!
and MIN, yea Boost solinoid was a two stage bleeder which switched from 5psi to 7psi at 4000rpm on RB25DET!!! The Guy is obviously confused..One of robert's 33's didn't pass tier 3 because of this exact reason. The hose from the compressor housing to the actuator is stock so no stress mate.
    • I get that taking off the head is best but that's a bit much for "just" valve seals. I was just under the impression that one would be able to rotate to TDC and be able to temporarily drop the valve without losing it and effectively having to remove the head to then recover it. I never knew people actually pushed rope into the cylinder to do valve seals hahaha So just to confirm, just going to TDC will not work? In that case I know when I do valve seals I'll maybe just remove the head and do some other things while I'm there, or just wait until I do an engine build.
    • The old approach was to fill the cylinder/chamber with a length of rope pushed in through the sparkplug hole. The new approach is to connect compressed air to the sparkplug hole and fill it with enough pressure to push the valves up. Doing either of these things with the head on and the engine in the car is a lot less pleasant than doing it properly.
    • Can't you put the pistons to TDC and then do the valve seals? Or will the drop down too far to pull them back up?
    • One thing I can tell you is, do it properly the first time. If you encounter unexpected problems just let the car sit for a week or two if you have to get some other parts or figure stuff out.  I'd have said go and use as many OEM parts as possible but since you want to change the turbo later on a custom kit is probably the better choice. Since I have no experience with RB25 just compare parts diagrams and images before buying a line kit and it should be easy to see if it has everything you need. Amayama has very good parts diagrams and part number lists, that is what I used a bunch to figure out what I might need. And don't forget to plan ahead and possibly renew other stuff that's easy to get to while you're in there doing the turbo lines. Happy wrenching
    • Update 4:   Hi all, good news. Engine is running and all the gaskets and seals seem to be working as intended. No leaks so far, even the JB Weld seems to hold. I flushed out the old coolant a few times and put in fresh coolant, not Nissan stuff, I decided to try the Ravenol Protect FL22, they claim it works for a wide variety of JDM cars and the opinions on it by some people were pretty good. And it has the nice poison green color! And man am I glad I bought a coolant system tester earlier this year, vacuum filling works wonders on this engine. I can definitely recommend this to anyone still doing it the old school way. All you need is compressed air supply. Will have to do a small test drive as soon as I can, I removed the gauge cluster again as the tacho needle was still bouncing around a bit but it was much better than before already.  I also found some cracks on all 4 tires inner and outer sidewalls. Apparently these tires should 't be parked on for extended periods or be kept under 0 degrees during storage, which I did not know. Clearly the previous owner didn't look into those details either, he probably bought them just cause they are cool semi-slicks. I'm just wondering how tf I am supposed to reach 30-80 degree tire temperatures on the public road consistenly, these tires were never going to work for my use case. I'll probably order Continental SportContact7 ones as these are the best allround summer tire available right now and I don't think I'll need anything crazier for now. Do let me know if you have experience with various tires and which ones you recommend.
