Has anyone changed the dash globes on a 32??? I have brought blue LED ones and was just wondering how long they take to fit???? might try and fit them today :D
took me around 3 hrs the first time I did it, 2 hrs the second time... also stripped my dash out yesterday which took 3 hrs to disassemble and around 2hrs to get 1/2 of it back on... its not too hard but if u have problems, send me a tell. worst comes to worst u can buy me booze and I'll do it for ya ;P
-D
anyone know when changing gearbox oil do you need to replace the filler and drain plug with new ones?
thanks Luke
dont need to replace the plugs unless the old ones are shagged. if still in good nick just clean the magnet and plug.
thanks to damo and chad about the jobi congrats. means alot! im scared as hell, start tomorrow working for a company called maison design as an all rounder.... called up friday, interview saturday, trial monday!! haha awesome!
http://maisondesign.com.au/
lol @ dohmar's lack of dash! looks hectic!
chad! we want pics!! :( havin fun getting intimate with your cluster?
hahaha yeah i know!! every little thing possible should be done in the first week to impress the boss! haha
thanks for well wishes! all helping me to amp up for the big day...... sorta like a dream place to be working
just got my dash led's working again steve...
i by-passed the dimmer knob (soldered the wires together)
and noticed there were still 2 not working, i mucked around with them switching them around, and now they all work!
its been a while since i have seen that!
i did notice one of the led's had melted though :(
meh, it still works, i just ordered white ones lol
Well I've got a bit of a head ache at the moment. I sold a diff to one of my mates and I shimmed it up and fitted it today, and after I had it in I was positioning it to line the bolt holes up and it fell out onto my head. For those who have picked up an R200 they would know they aren't that light.
So now i have an egg on my forehead the size of an actual egg.
    • Ok thanks..that was my second question if i can somehow bypass this even with Nistune(that is all i have right now...aparat from stock ECU. So with some aftemarket it can by "bypassed" or make it work?  I know there is Link or Haltech (mainly used). We have ECUmaster here so i will gather some info about it.
    • Yes. You will need to get the original boost sensor and wire it in. That is.... if you plan to use a stock ECU - even a Nistuned ECU. The Nissan ECU will not operate correctly without it connected. And yes, it will do annoying stuff like you are experiencing. You will almost certainly be better off with some aftermarket ECU, than trying to hunt down rare sensors.
    • Ok so ABS/TCS is "not" the problem. Yeah i know now about the ABS with Nistune(i told that to the Nistune guy) but iam not 100% why or why i dont have ABS. ABS cube is in the engine (always has been) but i had braked couple of times rly hard and brakes just locked and scream. Does all Skylines have ABS cube? That boost sensor https://www.sau.com.au/forums/topic/367633-wtb-r34-gtt-turbo-pressure-sensor-pics-inside/ Is this it? I need to ask but i have a picture of engine bay and i do not see that (100% is not in that place) If i do not have this the car can do what mine is?(cutting around 4000 rpm) Here is the pic of my engine bay(only one i have) BUT i think i dont have that cuz loom was used from my RB20DE NEO and i know (obviously) that it does not have boost control or any wire to that...) so maybe that is the problem? (i dont know for 100% if that car where the engine is from had that)...but i dont have the loom from that
    • I'm with you here. It's either loom has an issue, OR, injectors are not functioning properly. It could even be they're just constantly dribbling, hence the wet, but not firing.
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
