trailer is pretty much finished, took it for a dry run home (at 2am this morning). going to virginia afta lunch today to finish off the ramps, tidy up some of the unpainted welds and to load the car up.
note: anyone using nissan wheels on trailers, the inner lip of the bearing centre opening needs to be ground out, spent 3 hours last friday grinding the lip outta these
a few random photos for yas
last night, final touches
and how it stands this morning (still with a lil tidying up to be done)
Morning all... Just got a quick question i need to buy someone a birthday present this week and i wanna get them one of those diecast model cars the ones thats ya get in those display boxes, but im a little unsure where to get them, they want one of those inital d ones, you know the ones that ya can change the wheels and bodykits on... Does anyone know where i can find these....
cheers
mikey, last place i seen them was at motoquipe, so be a good idea to check there
*edit*
did anyone notice this thread: http://www.skylinesaustralia.com/forums/Ja...ry-t228959.html
Edited by Matty 31
is it just really cold or are you guys very fire safe when welding or sumthing? lol (fire retartend thingies on your heads)
that was 10:30pm at virginia
sorta combination of cold and also we were welding a bit of galv too................plus those balaklavas are RPM racegear ones (FIA approved) which my mate and i get supplied for our line of work as freebies hahaha
cheers
I use this place - http://www.biante.com.au/
But any toy shop or model shop should have some stock of what you are looking for there is a good model shop just off rundle mall that had rare models...
Hobby shop on main north rd? Is it still there?
I know the place your talking about i may have to pop in and see if they have em they didn't last time i was there but i will try again... cheers
auto barn can get the propper ones they come in a white box with papers and everything they can also order what you want
i'll give em a call and see what they say thanks heaps.
do a search for a manta racing's location in the same complex is a model shop he might be able to help you also
:D to Jess
:action-smiley-069: I will in adelaide in a few weekends time
Loving that trailer.
Whats the chances of you knocking me up a nice one for a motorbike?
I want specs of trailer looks nice and long! :P
Funny you mentioned them, I might shoot down to Aussie Dyno now & catch up with John Keen who I haven't seen in years then I was planning to catch up with Steve Cramp from Manta Racing who has some suspension for sale
    • I thought I'd come back and add something I JUST learned. A Toyota LandCruiser with a 1HZ, mates perfectly with a bottle of Nulon brake fluid. As in, it perfectly screws in. Great make shift funnel when you cut the bottom of it off. This may work for your Corolla.   Unfortunately, tipping a 10L drum is much harder than a 4 to 6L bottle, and they no longer include the easy pour tap which was just perfection to use previously.
    • Guys since i bought r33 gts25t coupe 1994 automatic a/t(manual swap 350z gearbox)  all i got is problems, always problems. Lets start with that when i turn key into ignition(ON) fuel pump doesnt always works. Sometimes i have to turn key twice Off/on/off/on until it primes. Its new, dw300 - 340lph. My gearbox broke so i did gearbox swap, install different intake manifold, injectors and i take pipes. Car was sitting in garage for more than half a year. I did assembly all not that long ago and when i turn ignition cant hear prime. All of sudden it stopped working. Theres many videos on YouTube how to make relay mod on r33 straight from battery so i did and it doesnt work! 😰 30 - battery positive  87 - positive from fuel pump to relay 85, 86 - one of two wires from original fuel pump wires(light blue, grey) and it didn’t work. so I check on ignition and took original BLUE relays wires from trunk, next to fuses. (I believe it’s IGN+ and ECU pin 18. it didn’t work…  tried connecting (IGN+ from og relay) and (ECU 104 from 1of4 FPCM wires) to my new relay 85/86 and it didn’t work.  I unplug FPCM. Didn’t work. im thinking what’s wrong   fuel pump is working, if I leave IGN+ on 85 and 86 straight to ground it works but it’s just nonstop. Since it getting constant 12v after key in ON. light blue wire gives me 6-8v.  so how this should be connected? What causing ECU not giving — on pin? Or I did sth wrong and that’s why it doesn’t work? I need negative signal on ECU that control fuel pump. What this should be?
    • You can use your VIN to look up the factory part number somewhere like amayama, and then look to order new if necessary. https://www.amayama.com/en/genuine-catalogs/nissan Depending on price you might want to rebuild instead. @GTSBoy I had an interesting insight into US market parts when the Titan rear calipers were sticking. New calipers were dirt cheap, about 20% more than a rebuild kit....they are just considered throw away maintenance items
    • Funny, but really not funny. Thank god (most) f the world has moved on since then
    • Lots of votes for driving onto a plank first; that is the quickest way I've found, 25mm is enough for my case but that will vary by car It also depends where you are going for. On the 32 I can get to the rear diff with my floor jack if I do that end first, and get it up on stands. Then I lift the front from either front tow hook as high as needed, also onto stands. Sometimes I need a small lift on the other tow hook to get it level enough If I do the front first I can't get to the rear diff because of the angle of the car Other options are getting to the front mount of the rear subframe from in front of the wheel (if only lifting one side, or just do both which is a bit of a pain compared to one lift from the diff), or also the gearbox cross member mount on the driver's side if you are  just trying to lift the driver's side. I This is the jack I use; it says 75mm clearance but of course that is only on the lower section so if you have to reach too far in like the diff you still get stuck. https://www.snapon-bluepoint.com.sg/category/Floor-Jacks/product/Floor-Jack,-2-Ton-Low-Profile
