just got back from uni snow trip 08 :D was awesome
never snowboarded before but moto for the week stolen from T Hawk was Go Hard or Go Home
hits
180, method grab (pics to come from someone else on the trip as my cam sucked n i fogot to bring the sd card)
misses well could call em hits to
lesson 1, dont place your leg behind the binder on the snow board when leaving the ski lift, slope go's up chair comes down leaving your leg jammed between feeling like it may break if something else dosnt give
lesson 2 when your friend boots it off before you do not overcook it trying to catch up, leaves me catching the wrong edge of the board and hitting the back of my head followed by the front. i couldnt see properly for 10min and had a headache for the next 2 days :D not to worry i kept bording
note this is the 2nd hit on the front here in the pic, lucky i had contacts in and no goggles on, it was also joked about the previous day i was the most likely to get injured :P
nissan sponsership deals on this mountain, i thought the 1st instructor was a nissan fan but then i realised they all had the same jacket with mt hotham written on it aswell. most people had subaru's there so i guess it aint working for nissan.
my good friend mr frostafied (i didnt build it as it takes forever to build 1)
highly recommend a trip like this to all, had f all sleep all week n just about all my body stings but it was worth it
the nice view and cliff edge (on the right in pic) some fool lost their snowboard down :D also spotted 2 people ski down it and come hiking back up 4hours later :) they have lifts in other spots guys they wernt even going for the snow board.
Edited by Inline 6
just got back from uni snow trip 08 :) was awesome
Hehe nice, hotham summit chairlift, I know it well. I'm gonna be renting a place on dinner plain next year :P Should be good
-D
yeah they had heaps of other 1s but they all said the pajero or some other nissan that i don't know started with m no doubt some sort of 4wd.
unfortunately stealing them is not possible unless you wanna climb the pole covered in ice with some wire cutters
2points to dohmar for spotting it was hotman, shoulda got a pic of this huge mt hotman writing in the snow people made looked awesome but as i said no pics for me :)
hopefully 1 of the other snap happy uni students got it
Edited by Inline 6
Yeah, massive rash on the other rims, thats a good rim! I'll grind out the rash at work then get them repainted, then they will look sweet :down:
please dont say those are the ones that are in the forsale section from psyco?
isnt it better off porting the old manifold then buying a new one? Pretty sure Matt (boostedR) was saying that stainless tend to crack and wont flow much more then porting a standard one.
i tig welded for 4 years so cracks dont bother me, cracks are usually because alot of manifolds aren't gusseted, wall thickness and penetration of welds. I got it really cheap so i dont really mind lol...its more of an experimental thing rather than chasing more power..
Edited by Ryanrb25
high mount or low mount ? (the stainless steel one that cracks)
    • I refreshed the OEM injectors with the kit and connected it up. It now ideals okay even with the IACV removed. Driving still has the same cutoff issue like the 550cc injectors so the issue is somewhere else. I bought FPG's Fuel Pump Hanger. I will be installing it next, but it is not as straightforward as I thought it was with my limited wiring knowledge and no instruction on the specific model I purchased (FPG-089). I also got the incorrect billet clamp as I could not find info on the OEM sizing.
    • Stop looking at the garage floor, and turn the radio up a bit louder if there's any strange noises...
    • No. Turbo shuffle and surge/flutter are not the same thing. Specifically, on a GTR, turbo shuffle has a definite meaning. On a GTR, the twin turbos are assumed to be the same thing and to operate the same way, exactly. In reality, they do not. Their exhaust sides are fed and exhaust a little differently, to each other. Their inlet sides are fed and exhausted a little differently, to each other. Consequently, when they are "working" they are often at slightly different points on the compressor map compared to each other. What this means, particularly when coming on boost, is that one of them will spool up and start producing extra flow compared to the other, which will put back pressure on that other compressor, which will push the operating point on that other compressor up (vertically). This will generally result in it bumping up against the surge line on the map, but even if it doesn't, it upsets the compressor and you get this surging shuffle back and forth between them That is "turbo shuffle" on a GTR. It is related to other flutter effects heard on other turbo systems, but it is a particular feature of the somewhat crappy outlet piping arrangement on RB26s. There are plenty of mods that have been attempted with varying levels of success. People have ground out and/or welded more material into the twin turbo pipe to try to prevent it. Extending the divider inside it works, removing material doesn't. There are aftermarket replacement twin turbo pipes available, and these exist pretty mush purely because of this shuffle problem.
    • You can temporarily* use lock collars to keep it in place until you can do the bushes, back the nuts off, slide them in, snug back up. *temporarily is often for ever
    • Thanks for the quick reply. To be clear, when you say turbo shuffle do you mean turbo flutter "stustustu" or referring to something else? I had thought they were the same thing. When I wrote the post my intention was to say it wasn't a flutter/compression surge sound. My understanding was that a flutter sound would be occurring when throttle is released, whereas I can keep the throttle in the same position for this noise
