just got back from uni snow trip 08 :D was awesome
never snowboarded before but moto for the week stolen from T Hawk was Go Hard or Go Home
hits
180, method grab (pics to come from someone else on the trip as my cam sucked n i fogot to bring the sd card)
misses well could call em hits to
lesson 1, dont place your leg behind the binder on the snow board when leaving the ski lift, slope go's up chair comes down leaving your leg jammed between feeling like it may break if something else dosnt give
lesson 2 when your friend boots it off before you do not overcook it trying to catch up, leaves me catching the wrong edge of the board and hitting the back of my head followed by the front. i couldnt see properly for 10min and had a headache for the next 2 days :D not to worry i kept bording
note this is the 2nd hit on the front here in the pic, lucky i had contacts in and no goggles on, it was also joked about the previous day i was the most likely to get injured :P
nissan sponsership deals on this mountain, i thought the 1st instructor was a nissan fan but then i realised they all had the same jacket with mt hotham written on it aswell. most people had subaru's there so i guess it aint working for nissan.
my good friend mr frostafied (i didnt build it as it takes forever to build 1)
highly recommend a trip like this to all, had f all sleep all week n just about all my body stings but it was worth it
the nice view and cliff edge (on the right in pic) some fool lost their snowboard down :D also spotted 2 people ski down it and come hiking back up 4hours later :) they have lifts in other spots guys they wernt even going for the snow board.
Edited by Inline 6
just got back from uni snow trip 08 :) was awesome
Hehe nice, hotham summit chairlift, I know it well. I'm gonna be renting a place on dinner plain next year :P Should be good
-D
yeah they had heaps of other 1s but they all said the pajero or some other nissan that i don't know started with m no doubt some sort of 4wd.
unfortunately stealing them is not possible unless you wanna climb the pole covered in ice with some wire cutters
2points to dohmar for spotting it was hotman, shoulda got a pic of this huge mt hotman writing in the snow people made looked awesome but as i said no pics for me :)
hopefully 1 of the other snap happy uni students got it
Edited by Inline 6
Yeah, massive rash on the other rims, thats a good rim! I'll grind out the rash at work then get them repainted, then they will look sweet :down:
please dont say those are the ones that are in the forsale section from psyco?
isnt it better off porting the old manifold then buying a new one? Pretty sure Matt (boostedR) was saying that stainless tend to crack and wont flow much more then porting a standard one.
i tig welded for 4 years so cracks dont bother me, cracks are usually because alot of manifolds aren't gusseted, wall thickness and penetration of welds. I got it really cheap so i dont really mind lol...its more of an experimental thing rather than chasing more power..
Edited by Ryanrb25
high mount or low mount ? (the stainless steel one that cracks)
    • I don't think the shuffle can damage the turbos. It only happens at low shaft speeds and loads. It's just annoying (to some people - others are tickled by the effect) and it quite possibly reduces spool performance a little bit.
    • Oh dear. The panel beating needs to be done before the filler work. Do you have a photo of the dent before you started? Hard enough to not flex and only hit the high spots?  What do you mean it was just temporary?
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
