Just a quick question, I spose many of you guys feel the same, but I'm selling my AWD Auto Subaru Liberty and want to get a Skyline. Dads not letting me get a turbo and I have persisted but only got yelled at some more.
His excuse is 'you never know when the turbo will kick in and throw you sideways'. Thats about it. 'It would be irresponsible of me to let you get a turbo', 'Not at 17 years old' and all that stuff.
Is there any hard facts about this that can be to my advantage? Stock boost does crap all? You can't feel it? etc etc. He'd let me get a non turbo R33 (140kw) but not a turbo R32 (158kw). 'The disk brakes on the R32 explode and they're generally the worst one of them, the R33 is the pick of the bunch'.
Any common problems the non turbo has that the turbo doesn't? This is concerning both R32 and R33 models.
And for anyone saying how I'm going to be irresponsible and all this stuff, I've had this drilled into by my Dad more then enough. When I go driving with my mates I tell them not to speed and don't care if they get ahead of me. They do stupid stuff and I know who's car not to get into. Even complaining to my sister she reckons I'm the most responsible 17 year old she knows. Ask Kahli on here for some backup, she knows how I drive.
Thanks for any replies, but this is something I really want (I've already bought a car that was 'alright I guess' but not what I want. I don't wanna do the same again). Plus if I get a non turbo, my mates have already got a nick name lined up for me :rofl:
LOL well i came from a vs auto to a stock standard 32 gts-t, yes there is a power dif and i would def reconmend getting manual as i find it alot safer. In the end u aint gunna get sideweays unless u put ur foot down no matter what car u have!
hows is comming on at a certain rev range every single time 'you never know' going sideways is simple DONT clutch kick
common problem with non turbo is lack of power when you need it
Thanks for any replies, but this is something I really want (I've already bought a car that was 'alright I guess' but not what I want. I don't wanna do the same again). Plus if I get a non turbo, my mates have already got a nick name lined up for me :(
DONT listen to him thats the expensive way around
find a r32 with a rb25de and when ur older slap a 30 bottom and run 250+ rwkw :D lol
lol +1
So the post whores are back in town :rofl: was very quite without you guys :(
ah, so SAU isnt :D'ed from blanchetown thats good to hear :P
Yes, a couple of noticeable absences, CHAD AND JENKIES! Will probably be doing it again soon tho, was awesome fun!
and this talk about RB30 bottom end gets very expensive very quick if you dont do it right the first time which is moderately expensive
oh cool ill drop that water pump off after work sometime this week you name a day i finish most days @ 7pm but tues will finish @ 5:30
I appreciate that steve but this week is really bad. We've had a close friend suicide and I honestly don't know what my movements are going to be this week... ill msg you and work out a time later
-D
4wd yeah its a pain in the arse as there is the plenum issue if you run an rb25det. Typically for a 4wd you can budget an additional 1k over a std rb26dett rebuild. If its the rb25det then you need low mount plenum.
RWD - the additional cost is very minimal and well worth the huge amount of mid range compared to the 25. No reason it should cost more than an additional 300-400 max.
Back when I did mine it worked out cheaper to do a std rb30 freshen up with an rb25 head than it was to grab a rb25det and drop that in.
ur lucky to get a non turbo r 33!
i was only allowed a front wheel drive!!!
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
