Just a quick question, I spose many of you guys feel the same, but I'm selling my AWD Auto Subaru Liberty and want to get a Skyline. Dads not letting me get a turbo and I have persisted but only got yelled at some more.
His excuse is 'you never know when the turbo will kick in and throw you sideways'. Thats about it. 'It would be irresponsible of me to let you get a turbo', 'Not at 17 years old' and all that stuff.
Is there any hard facts about this that can be to my advantage? Stock boost does crap all? You can't feel it? etc etc. He'd let me get a non turbo R33 (140kw) but not a turbo R32 (158kw). 'The disk brakes on the R32 explode and they're generally the worst one of them, the R33 is the pick of the bunch'.
Any common problems the non turbo has that the turbo doesn't? This is concerning both R32 and R33 models.
And for anyone saying how I'm going to be irresponsible and all this stuff, I've had this drilled into by my Dad more then enough. When I go driving with my mates I tell them not to speed and don't care if they get ahead of me. They do stupid stuff and I know who's car not to get into. Even complaining to my sister she reckons I'm the most responsible 17 year old she knows. Ask Kahli on here for some backup, she knows how I drive.
Thanks for any replies, but this is something I really want (I've already bought a car that was 'alright I guess' but not what I want. I don't wanna do the same again). Plus if I get a non turbo, my mates have already got a nick name lined up for me :rofl:
LOL well i came from a vs auto to a stock standard 32 gts-t, yes there is a power dif and i would def reconmend getting manual as i find it alot safer. In the end u aint gunna get sideweays unless u put ur foot down no matter what car u have!
hows is comming on at a certain rev range every single time 'you never know' going sideways is simple DONT clutch kick
common problem with non turbo is lack of power when you need it
Thanks for any replies, but this is something I really want (I've already bought a car that was 'alright I guess' but not what I want. I don't wanna do the same again). Plus if I get a non turbo, my mates have already got a nick name lined up for me :(
DONT listen to him thats the expensive way around
find a r32 with a rb25de and when ur older slap a 30 bottom and run 250+ rwkw :D lol
lol +1
So the post whores are back in town :rofl: was very quite without you guys :(
ah, so SAU isnt :D'ed from blanchetown thats good to hear :P
Yes, a couple of noticeable absences, CHAD AND JENKIES! Will probably be doing it again soon tho, was awesome fun!
and this talk about RB30 bottom end gets very expensive very quick if you dont do it right the first time which is moderately expensive
oh cool ill drop that water pump off after work sometime this week you name a day i finish most days @ 7pm but tues will finish @ 5:30
I appreciate that steve but this week is really bad. We've had a close friend suicide and I honestly don't know what my movements are going to be this week... ill msg you and work out a time later
-D
4wd yeah its a pain in the arse as there is the plenum issue if you run an rb25det. Typically for a 4wd you can budget an additional 1k over a std rb26dett rebuild. If its the rb25det then you need low mount plenum.
RWD - the additional cost is very minimal and well worth the huge amount of mid range compared to the 25. No reason it should cost more than an additional 300-400 max.
Back when I did mine it worked out cheaper to do a std rb30 freshen up with an rb25 head than it was to grab a rb25det and drop that in.
ur lucky to get a non turbo r 33!
i was only allowed a front wheel drive!!!
    • I refreshed the OEM injectors with the kit and connected it up. It now ideals okay even with the IACV removed. Driving still has the same cutoff issue like the 550cc injectors so the issue is somewhere else. I bought FPG's Fuel Pump Hanger. I will be installing it next, but it is not as straightforward as I thought it was with my limited wiring knowledge and no instruction on the specific model I purchased (FPG-089). I also got the incorrect billet clamp as I could not find info on the OEM sizing.
    • Stop looking at the garage floor, and turn the radio up a bit louder if there's any strange noises...
    • No. Turbo shuffle and surge/flutter are not the same thing. Specifically, on a GTR, turbo shuffle has a definite meaning. On a GTR, the twin turbos are assumed to be the same thing and to operate the same way, exactly. In reality, they do not. Their exhaust sides are fed and exhaust a little differently, to each other. Their inlet sides are fed and exhausted a little differently, to each other. Consequently, when they are "working" they are often at slightly different points on the compressor map compared to each other. What this means, particularly when coming on boost, is that one of them will spool up and start producing extra flow compared to the other, which will put back pressure on that other compressor, which will push the operating point on that other compressor up (vertically). This will generally result in it bumping up against the surge line on the map, but even if it doesn't, it upsets the compressor and you get this surging shuffle back and forth between them That is "turbo shuffle" on a GTR. It is related to other flutter effects heard on other turbo systems, but it is a particular feature of the somewhat crappy outlet piping arrangement on RB26s. There are plenty of mods that have been attempted with varying levels of success. People have ground out and/or welded more material into the twin turbo pipe to try to prevent it. Extending the divider inside it works, removing material doesn't. There are aftermarket replacement twin turbo pipes available, and these exist pretty mush purely because of this shuffle problem.
    • You can temporarily* use lock collars to keep it in place until you can do the bushes, back the nuts off, slide them in, snug back up. *temporarily is often for ever
    • Thanks for the quick reply. To be clear, when you say turbo shuffle do you mean turbo flutter "stustustu" or referring to something else? I had thought they were the same thing. When I wrote the post my intention was to say it wasn't a flutter/compression surge sound. My understanding was that a flutter sound would be occurring when throttle is released, whereas I can keep the throttle in the same position for this noise
