Just a quick question, I spose many of you guys feel the same, but I'm selling my AWD Auto Subaru Liberty and want to get a Skyline. Dads not letting me get a turbo and I have persisted but only got yelled at some more.
His excuse is 'you never know when the turbo will kick in and throw you sideways'. Thats about it. 'It would be irresponsible of me to let you get a turbo', 'Not at 17 years old' and all that stuff.
Is there any hard facts about this that can be to my advantage? Stock boost does crap all? You can't feel it? etc etc. He'd let me get a non turbo R33 (140kw) but not a turbo R32 (158kw). 'The disk brakes on the R32 explode and they're generally the worst one of them, the R33 is the pick of the bunch'.
Any common problems the non turbo has that the turbo doesn't? This is concerning both R32 and R33 models.
And for anyone saying how I'm going to be irresponsible and all this stuff, I've had this drilled into by my Dad more then enough. When I go driving with my mates I tell them not to speed and don't care if they get ahead of me. They do stupid stuff and I know who's car not to get into. Even complaining to my sister she reckons I'm the most responsible 17 year old she knows. Ask Kahli on here for some backup, she knows how I drive.
Thanks for any replies, but this is something I really want (I've already bought a car that was 'alright I guess' but not what I want. I don't wanna do the same again). Plus if I get a non turbo, my mates have already got a nick name lined up for me :P
Ask your dad to get you some defensive driving lesson if he reckon's you wont be able to handle a turbo...Heslo was looking at doing this event later this year..
There great fun and you learn how to handle a car from experts at the same time!
195s or 225s im pretty sure it can be done :D
Can be but it's f**king pointless. Get something a bit wider. 225/50. If you want to run a 195 tyre you might as well get an 8 inch wheel.
There's stretched and then there's stupidity. Im guessing they're for 16 x 10 challengers?
That being said, you'll be hard pressed to find a tyre changer who will. Not even adelaide tyrepower (the masters of stretch) will do it.
Hope you enjoy popping beads.
    • That R31 was so cool. Only did Orange Park once. Scared the hell out of me.
    • Selling my TE37SLs since I've switched to smaller wheels.  They're for sale in Japan but it's pretty simple to send them overseas; USA excluded, since JPPost isn't sending there at the moment. Specs Front: 18x9.5j +22 5x114 Rear: 18x10j +20 5x114 Price: 320,000 JPY/ 3,285 AUD (current FX rate) Condition: a few scratches here and there, no bends, distortions or cracks.  Tires will not be included for international buyers, I'll get them dismounted before shipping. They're currently listed on yahoo auction and will be shipped in Japan with the tires if they sell here. Shipping costs to Aus: EMS (1-2 weeks): AUD 1,175 (current FX rate) Sea (2 months): AUD 460  (current FX rate)
    • The alloy coolant reservoir has a sight glass, so as long as I can see coolant in the sight glass it's GTG, as for PS, it isn't anything catastrophic if it gets low, and as it hasn't lost a drop since I have owned the car I cannot see it being an issue, even after putting the "big block" 2.5 in....LOL The only time it gets slightly messy is at oil changes, as the oil filter sits above the frame, and I need to use a plastic bottle with its bottom cut off to catch the flow when loosening the filter
    • Good on you for taking on the job, but it is a big one. Even if you have bolt on manifold and turbo, you will need: Post throttle pressure source to boost controller to wastegate (and FPR, and ECU/MAP sensor) Pre throttle pressure source to top of BOV(s) Oil feed - you can take that from the standard port in the middle of the block Oil return to block under the turbo - this is much trickier than it seems to route a decent/wide pipe past the manifold. You really can't use rubber hose because it is way too hot there, and also the oil out of the turbo core is a bit frothy so it needs to have a decent diameter Water feed - you can take that from the standard port in the rear of the block. Water return - mine runs to a T into the heater box return, just make sure you don't create a high point making bleeding hard. All of those lines should use 200 series style teflon braided hose with heat shielding because everything needs to be routed past the manifold. Also a turbo beanie is a really good idea to minimise the chance of the car catching fire (under bonnet lining in particular) You also need to decide a cam cover breathing solution as well, will you vent externally via a catch can (probably illegal) or return to the intake (plumbing required and can oil up everything over time) Keep in mind the intake and exhaust piping in the engine bay will be custom so you either need to be able to fab ally and steel or have someone you can get a car that isn't running to. Get the wideband fitting welded into the dump pipe at the same time. Also, just my opinion, a screamer pipe attracts attention and doesn't add power, I'd plumb it back if you want to be allowed to keep the car on the road. BTW do you know anything about how healthy the motor is, and what power you are targeting? Doubling or tripling the factory power on an unknown motor is a little risky. Also fuel system will need some attention (pumps, high current hanger, direct power and earth feed, injectors etc)
