I'm back from interstate! 4 states in 1 four day weekend, over 3,000kms. I'm rooted :D
Picked up a Dolphin bodykit for the Stag. Just need to paint it black ... then I'll take pics :D
Very Nice Matty!!
Does the 31 overhang at the back much?
We need the long ramps as well, lucky the GTR front bars have that plastic lip at the bottom cause at least its flex's a bit as rubs when using short ramps
yes, ive missed a whole week's worth of posting
the 31 overhangs about 2" at the most at the back
brake issues were resolved last minute, seems the drums werent adjusted and were dragging. got them sorted last thing wed nite
did 1600km over the weekend, including the drive over and back, and its awesome. as is the patrol. sat on 110 the whole way back today, and was a breeze. also a breeze to unload
winton was fun too :glare:
I'm back from interstate! 4 states in 1 four day weekend, over 3,000kms. I'm rooted ;)
Picked up a Dolphin bodykit for the Stag. Just need to paint it black ... then I'll take pics :glare:
Whereabouts did you go?
Longest trip I've done is Adelaide-Warrnambool (via Grampians)-Albury (via Melbourne)-Sydney-Adelaide
Now that was a trip!
id say congrats!
id be happy if my missus was to fall preggers.......just have to slow down on the mods on the 33 :D
You'd need to get a sparco baby seat :D
I'd be shit scared if the missus fell pregnant. Not to say I wouldn't keep it but just not ready for that at this stage of my life
+1. mind you i am only 20.
    • I refreshed the OEM injectors with the kit and connected it up. It now ideals okay even with the IACV removed. Driving still has the same cutoff issue like the 550cc injectors so the issue is somewhere else. I bought FPG's Fuel Pump Hanger. I will be installing it next, but it is not as straightforward as I thought it was with my limited wiring knowledge and no instruction on the specific model I purchased (FPG-089). I also got the incorrect billet clamp as I could not find info on the OEM sizing.
    • Stop looking at the garage floor, and turn the radio up a bit louder if there's any strange noises...
    • No. Turbo shuffle and surge/flutter are not the same thing. Specifically, on a GTR, turbo shuffle has a definite meaning. On a GTR, the twin turbos are assumed to be the same thing and to operate the same way, exactly. In reality, they do not. Their exhaust sides are fed and exhaust a little differently, to each other. Their inlet sides are fed and exhausted a little differently, to each other. Consequently, when they are "working" they are often at slightly different points on the compressor map compared to each other. What this means, particularly when coming on boost, is that one of them will spool up and start producing extra flow compared to the other, which will put back pressure on that other compressor, which will push the operating point on that other compressor up (vertically). This will generally result in it bumping up against the surge line on the map, but even if it doesn't, it upsets the compressor and you get this surging shuffle back and forth between them That is "turbo shuffle" on a GTR. It is related to other flutter effects heard on other turbo systems, but it is a particular feature of the somewhat crappy outlet piping arrangement on RB26s. There are plenty of mods that have been attempted with varying levels of success. People have ground out and/or welded more material into the twin turbo pipe to try to prevent it. Extending the divider inside it works, removing material doesn't. There are aftermarket replacement twin turbo pipes available, and these exist pretty mush purely because of this shuffle problem.
    • You can temporarily* use lock collars to keep it in place until you can do the bushes, back the nuts off, slide them in, snug back up. *temporarily is often for ever
    • Thanks for the quick reply. To be clear, when you say turbo shuffle do you mean turbo flutter "stustustu" or referring to something else? I had thought they were the same thing. When I wrote the post my intention was to say it wasn't a flutter/compression surge sound. My understanding was that a flutter sound would be occurring when throttle is released, whereas I can keep the throttle in the same position for this noise
