anyone know much about R34 GTR engine harnesses? Found one for sale on the Jap auctions and just wanna know if everything is there.
Apparently they are very hard to find and can be very expensive. This is roughly $500del
yep, looks all there to me! :(
hehe.. depends on what falcon.. the older ones are plagued with crank end float issues and head stud problems. :D
Falcons definitely a better pick than the commodores especially for towing. :mad:
See if you can pick up an old EF/EL 4ltr 5speed then umm strap a turbo on to it. 1550kg kerb weight vs the BA's 1700-1800kg. = power to weight FTW :wub:
I used one of those cheap $5 1/4" drive ratchet kits from supercheap that come with philips head bits. You can get heaps of weight on to it + leverage so they crack easily.
Thanks cubes, will give that a try :(
I haven't actually played with the cam gears yet.. Left them as is as there's still a bit of work to be done with the 2" fmic piping etc.
Im still getting my head around cam specs etc..
My understanding is there's:
~39degree's overlap seat to seat and -4degree's overlap at 0.050"
R32 RB25DE cams:
~8degree's overlap seat to seat. No idea at 0.050". All though I believe 0.050" overlap you ignore?
R32 RB20DET cams:
~5degree's overlap seat to seat.
R33 RB26:
~7degree's overlap seat to seat
So it is running a fair whack of overlap. I was pretty way off.
Ok, where do we start.
Your cams have 112deg of separation from IN to EX lobe centres which does not give you the actual overlap figure (can vary depending on lift & lobe profile).
I made a mistake in calculation in the earlier post and said you had 50deg overlap when its actually more like 40deg (I based it on a 25/65 grind rather than a 20/65).
Like I said earlier, when you increase duration you generally increase overlap so normally I would suggest you pull the IN & EX lobes further apart with gears and actually consider a figure of around 116deg of separation, but in your case I probably wouldn't bother if you're already getting good low down flexibilty.
Cranking pressure now sits at 155psi vs 158psi with the std cams.
But whats wierd is this engine analyzer pro is stating there's 28degree's of overlap?! :S
Not unusual although I expected that you would've pulled a little more compression out of the cylinders than you actually did, so its not too bad.........as for the analyzer, send it to a shrink to get analyzed :P .
On the note of compression, so many peeps opt for thicker head gasket shims in order to be able to run higher boosts but they forget you can do it with cams. So when they do cams and thicker head gasket at the same time, they wonder why they've lost so much compression. A little bit of compression is what makes the RB's so nimble so you don't want to dial out too much.
The cams are unfortunately as big as you can go without seriously looking at valve springs, solid lifters and machining the buckets. The 26 head is a much better starting point for 350rwkw+.
Yeah I agree, you've got a good street grind there with a smidge under 9mm lift which is the main determining factor for what springs and retainers you run, so your current springs (if in good order) will be fine. Definitely need to use different springs once you go over 10mm of valve lift. Good thing about RB's is 1:1 ratio unlike other engines that have to factor in extending rocker ratios as well. ;)
What I have unexpectedly experienced is a very noticable improvement in economy. We didn't play with the ignition map its the std rb26 one. The afr's were set back to 15:1 and that was it.
Driving the car to work the last week and quite a bit of driving on the weekend its consistently floating between 10.5-11L/100km's. The last tank pulled 480km's out of 52litres.
Hmmm, thats a tuffie.
I'm assuming 15:1 AFR's is at idle only and even thats abit lean, should be around 14:1 but I dont think that really matters too much.
I need to see your graphs to see what the rest of you AFR's are doing. The guy may have pulled a fair whack of fuel out of the map which could explain the good economy.....hope its not running too lean :P
I wouldn't mess with the ignition map yet until you determine what yo want to do with the gears. Pulling out abit of valve timing will alow you to advance the ignition a bit more without the extra fear of detonation.....so you gain a bit more power and bring it back where its a bit more useable at the same time.
You may be able to help me get my head around the following.
Retarding (or is it advancing?) the inlet cam does that numerically increase the Inlet LCA which widens the LSA and as a result decreases overlap.
And the exhaust.. retarding or advancing does that increase the LCA or decrease numerically? :S
Inlet LCA of 115, Exhaust LCA of 118 gives an LSA of 116.5 and 31degree's of overlap. Reduced overlap might help that restrictive gt30 .82 rear end up top.
Pretty much as I said above, but at the end of the day its all about how it feels on the road.
I'd start with about 4 degrees reatard at the crank (2 lines) on the EX cam gear and see how it looks on the dyno.
Just did a search.......Check out SK's thread that probably explains it better than me....I'm definitely no RB guru but he is.
Adj Camshaft Pulley
Well guys it looks like were putting off that SAU cruise/bruise past the dads place then. ;)
haha, yeah I think that idea has been shelved temporarily.
I was gonna back up the 300 tyre over his head :P
Hey Amanda......tell him if he messes with you, he messes with the whole SAU family........he may wake up with a horses head next to him one day :P
What the hell are you kids talking about ? You sound like a bunch of darned star trek fans
-D
    • Decided to upgrade my pressurised plastic coolant expansion tank for a fancy pants alloy version The OEM versions can get brittle, even the new plastic one I got when I first got the car is a starting to show signs of "stress" I wasn't cheap, but it is basically unbreakable
    • Morning all, I have an RB25DET Neo that's in need of a rebuild. Will need new pistons etc due to detonation damage. Would anyone be able to recommend a shop in Southeast Queensland who I could bring my long motor to for a rebuild? Just want someone who knows RBs and whos built a bunch of them before. TLDR - recommended engine shops for RB rebuild.
    • Gday Thought it was about time I started a build thread! As expected this project has snowballed into a huge financial liability, but unless you’re strong willed and responsible, it’s not a surprise. Background -  My first turbo car was an R32 GTS-4, got my full license and then totalled my Au Falcon a week later, so while trying to sell my RMZ450 dirtbike to buy another car a bloke offered to swap the R32 which at the time I felt like I was ripped off but looking back and seeing prices of those now ($40kish) it was a good deal, I didn’t know enough about these cars to appreciate what I had so sold it before the RB20 blew up. Between here and there, out of 12 cars I’ve owned the note worthy ones are a V8 Lexus SC400 (soarer), a couple of XR6 Turbos and my beloved S15 which I had for about 3 years, picked it up for $12500, repairable write off but she was fine, gun metal grey/pewter and bone stock/unmolested until I got my hands on it. Ended up spending about the value of the car and 280kw, 2 demerit points by the time I got defected and sold it for $14500 (also $40kish in today’s market, rip) Fast forward to the present day, I’m in a much better position financially and daily an MQ Triton (great cars, pipe down Ranger Bois), I cruised marketplace and car sales for a few months looking for another R32, the best deal I could find was an absolute rust bucket half finished project for $12000, until this R33 popped up in Port Macquarie for $18k - unregistered and barely running but decent shape, kept an eye on it for a few weeks and the price steadily dropped, $16k then $15k then $14k, that was the point where I was like shit someone’s gonna snatch this up! It was owned by a young bloke who had big plans but him and his missus just had a baby so smartest move financially for them but big gain for me. So 2 days later I’m towing a car trailer to pick this thing up. Roughly 2 weeks and $3500 later I’m cruising around Newcastle in my beat up R33 all smiles and dose noises! It only needed some basic shit to get it going, coil packs and air flow meter, electrical stuff and all fluids changed, 158k kms and running pretty good, nice smooth engine after oil and coolant flush - when I say coolant I mean it had been filled up with tap water, every gallery and heater element was filled with rust, 8-9 flushes later and still had brown liquid coming out but she’ll be right. The car was painted R34 Bayside Blue at some point but whether it was a cheap job or just not looked after is anyone’s guess, clear coat flaking like sausage roll.  Was rethinking my choices and contemplating life, had it up for sale for $22k - still cheaper than any registered R33 but got little interest, next minute I had an opportunity at work - 6 months overseas for good money, so that was a no brainer, fast forward again and here we are with a 50% finished project. Current Mods - 200ish KW according to butt dyno Was tuned with Apexi PowerFC EBC (old school Greddy Profec)  Stock turbo (more shaft play than a Tinder date gone right) 3inch turbo back Varex muffler  Aftermarket injectors of mystery size, Power FC showed 36% duty cycle at full boost so not behd good size Someone had good intentions but stuck with the stock R33 MAF so we had misfires at 6000rpm due to the MAF hitting 5.2V So far I’ve redone the entire interior with carpet form Car Mats Direct, new Seats and steering wheel from Autotechnica, also sound system by Autobarn (mainly Kicker) Also MCA pro comfort coil overs - Hands down best purchase yet, worlds of improvement over the tired 30yrold shocks Goals - 450kw/600hp on flex tune New paint job - Midnight Purple 2 Engine is at the shop getting rebuilt with forged rods a pistons, new valves and springs, ATI Harmonic balancer, Aeroflow 7.5L sump, rear head drain and oil restrictors as per oil control thread* and cam covers modded for larger breathers, other stuff I can’t recall of the top of my head Parts purchased and to be installed once the engine is done -  Engine loom from Wiring Specialties including these options: Haltech Nexus S3 R35 Coil pack conversion  PRP Dual Trigger kit Fan controller  Other Parts -  262 Kelford Cams Turbo - Hypergear ATR43SS3-ProS with T51R mod (whistly boi) 6 boost manifold (high mount) 50mm Turbosmart Pro gate (plumbed back for legal reasons) HKS Super Turbo Exhaust with High Flow Cat Custom 3.5inch dump and front pipe 1500cc Bosch injectors  Fuel Pump walbro 525 Haltech MAP and IAT sensors Haltech Flex Sensor Fenix Radiator with dual thermo fans LS1 Alternator Kit Oil Filter Relocation from EFI solutions and Cooling pro oil cooler Many other things sitting in my garage waiting for that engine to come back. Progress pics to follow -
    • Losses have to be less with DC coupling. Provided the battery inverter has decent MPP tracking ability - which really shouldn't be a problem. It's not 2005 any more.
    • Hi, Will the R33 GTR rear brake backing plates fit a GTST? I'm struggling to find GTST ones but can find new GTR ones.   Thanks.
