RB26 pump... MEEE!!!!!!!!!!!! im looking at doing major service in the next month or so!
no probz bud, I'll put it aside for you and if I'm not on the bike tomorrow night I'll bring it to Villis......will you be there at 7pm?
Just fix me up when you can, I'm not that desperate for the cash at the moment if you don't have it yet.
Can I have sex with someone to pay my debt? Preferably female/human female. Preferably alive. Preferably under 80. Got any bad debt u wanna swap sleddo my man?
-D
ohhh maaan!! I'm out of black ink and I'm 1/2 way through printing a report.
Anyone have a T0491 Epson cartridge for an RX650 that they can send through the email :down:
no but if u want I can print it out for u and u can pick it up. just got new inks for my bubblejet on tues
-D
yeah, i'll be there and will probably have the money.
anyonw looking at doing an N1 oil pump group buy, or nismo timing belt?? =P
try Joelo for gates timing belts but I wouldn't waste your money on an N1 oil pump
funny thing, of the 2 or 3 mechanics i've mentioned the 100k service to all have said to not worry about the N1 water pump, but to get the N1 oil pump... maybe its just an R32 thing... =D
was going to just get sock timing belt, but BANNED sugested that for a few extra $$ the nismo one is probably a better buy.
yeah at the end of the day you don't really need either pump but for the same reason you're going for a better Belt (ie. few $$ more) you are better off with the N1 waterpump.
On the other hand the N1 oil pump costs an extra 3 arms & 4 legs, lol........and with the overhead oiling issues that RB's are renown for, why would you want to exacerbate the problem.
Maybe your mechanics are not very familiar with RB engines?
EDIT:
Gates or Nismo are in the same league.....both have kevlar in them. Also, waterpumps will give up the ghost under normal circumstances way before oil pumps.
    • I was 99% sure the standard one is long enough to get there, you might just have to change the throttle orientation. If not, I remember someone having used an r31 cable instead, but that is probably harder to find than r33 by now...
    • HELP   Hey all, Is there an accelerator cable from another Nissan that can be used on the R33 GTST RB25DET with a Greddy forward facing plenum?  Thanks in advance  Rob
    • Or do we think it was installed to give 1 bar of boost max, all day, everyday?
    • So could it be assumed it has been installed intentionally with potentially a power FC boost controller kit?
    • Had my rig on Matt's dyno at PITS the other day. After a few years between tunes I added a few sensors and swapped intercoolers. Result. 553hp at 26psi. Not bad for an FJ20 that was built in 2007. The problem.. It filled the overflow bottle on hard runs which leads me to believe the head gasket isn't sealing. I have a coolant pressure sensor which was reading cap pressure at 22psi and occasionally overrunning to 23/24 psi on deceleration after a pull. It was not spiking. It has arp2000 head studs and a cometic gasket. As its been 18 years in service, I pulled the engine out and head off. Everything looks good but we obviously have an issue. Where I'm at.. Years ago I had the same issue, I checked the stud tension and they were all over the place. Some at 60 to 70 and some up near 90. I nipped them all to 100ft lbs and this stopped the water push until now. I believe this compromised the gasket back then. What do I do? 2 options are..  1) I bought arp 625+s, which I could put in with a new gasket. Thinking Kameari this time, reassemble and try again. 2) strip the block, get fire rings machined in with copper gasket and try that. I do not want to push it more than 28 to 30psi. I think the turbo will be out by then anyway. (G30-770). My other concern is the long term ability of a copper head gasket. Are they streetable for years? I feel like a new gasket with the new studs will probably suffice, but I don't know. Any thoughts welcome and advice on copper gaskets and fire rings. Thanks!
