whos got trader plates? just scored me 4wd swift fresh from japan.
thnx bro :P
take it its gonna need a day registration permit or something
was nice of him to keep it a secret until i get a letter saying remove this suzuki from our docks
Edited by Inline 6
thnx bro :(
I demand pictures! :P
no idea mate, my bro dont like to tell me shit havnt heard from him in like 2months n a letter from the docks just rolls up.
its gota be newer than 1990 though its a mk3 swift, i somehow think its gonna struggle to break traction
^^ its nothing special just a stock mk3 swift like 1993ish jap version has 4wd my bros got vids on youtube of it drifting in the snow ill try n dig up 1
Edited by Inline 6
skip 1 min in the footage at the start dont work right.
that is the actual 1 he bought, never been thrashed :P silly boy didnt wanna go through the hassles of buying off someone who dont speak english but surely coulda found a nicer condition 1
Hmmm hope you're not planning to register said vehicle as I don't think compliance would be available for such a similar car to one sold here in mass volume. Would make a good little rally car though :P
yeah registering is the plan, not my prob though not my car.
its been done before theres about 5 in the country already. although i think this is the 1st set for adelaide
the engine's a lil different aswell makes like a whoping extra 10hp :P
Edited by Inline 6
Neg for first in Adelaide, theres a convertible Cultus up here in Littlehampton. Haven't seen it around for years though (used to see it regularly back when I was in school)
you sure it just wasnt badged cultus.
i heard all the convertables were just cino edition swifts fwd n not even as powerful as the gti never heard of convertable cultus.
my bro's a damn suzuki expert ill find out when i finally catch up with him :P
there's vids of a converted rwd cultus that 1 looked like fun :(
I dunno I just assumed Cultus was the JDM name for them :(
so Cultus is the highest spec level (turb, 4WD and Jap only), GTi was our highest spec level (FWD and quickish 1.3) and the Cino was the pov pack?
I don't really care for Suzukis so never bothered to learn the model variations :P
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
    • Nah, that is hella wrong. If I do a simple linear between 150°C (0.407v) and 50°C (2.98v) I get the formula Temperature = -38.8651*voltage + 165.8181 It is perfectly correct at 50 and 150, but it is as much as 20° out in the region of 110°C, because the actual data is significantly non-linear there. It is no more than 4° out down at the lowest temperatures, but is is seriously shit almost everywhere. I cannot believe that the instruction is to do a 2 point linear fit. I would say the method I used previously would have to be better.
