hows this hyundai wanted $234.34 for an injector for a 2000 hyundai accent, stanvac auto wreckers will give me one for $30 lol. :thumbsup: now i just have to put it in haha.
I paid $330 for a genuine GTR injector from Japan! I needed 6! Ended up costing me like $2200...
I could have bought a Hyundai Excel for that haha
totally.... u can get sard 800cc's for $900 or something on the GB section... crikey
-D
Haha yeah I know, my mechanic told me that he could get a full set for that + a tune! But I need a ECU which isn't on the cards at the moment.
But it really is the going price for the genuine injectors. I rang up Nissan, and they told me $360 each. Apparently the GTR injectors are becoming more sought-after now due to the fact that most of the older model GTR's injectors are begining to leak.
But, 6 new injectors later, the GTR's running alot better and no more fuel smell!
Crickey you can get sard 800's for a little over 600 your all getting ripped off
and go see a new mechanic because someone like Jeff from the speed lab could of remaped your standard ecu and you still had change for a beer from $900
hahaha google street photo taken when my car is not home :thumbsup: though i did want to see it
Yeah I checked my house first and there wasn't any cars home, so I did the following:
lol k i checked my house my old work and my new work and my mates house and its not there ether...haha im checking the x's house now lol,seriously tho where the hell was i on this day!
:ermm:
Yeah, lobethal was done around the time we had that heat wave, and some parts of Nairne were done at a later/earlier time in the year, as it's all cloudy and shit in the pics (the loby pics are fkn sunny as, with dead grass every where :P)
Sard injectos and an ecu remap for $1000 you say? Not bad. Think its the actual injector leaking, not because of the o ring... Can actually see fuel running out :S not much, but enough.
That's exactly the issue I had. Shaun was saying how alot of the 32 GTR's are doing this now with the stock injectors. I had 2 leaking, though and the others were on their way to that point.
You get a bad fuel smell, too. Everywhere I took it, people would say "you've been giving this one a flogging!! I can smell the fuel still!" haha
(virtual)drive down the main street of barker, just after the bike shop its sunny, then move ahead one spot and its dark, wet and cloudy. haha.
    • It says 300ZX, does that make it an Aus delivered car? Funny how back in the day I just couldn't care less about Z32's and these days I am just in love with them. Back when Nissan was into pushing the envelope. 🤣
    • Hi guys, just after some guidance with an R34 sunroof that has stopped working correctly. It still opens and closes perfectly fine, but it no longer tilts/vents up or down. As a result, the rear of the glass now sags a bit as it drops down slightly in order to retract into the roof, but now it can't pop upwards into a flush position. I’ve probed the pins on the back of the switch connector with a multimeter and it seems like both switches (for open/close and tilt/vent) still work correctly. Any ideas on what it could be, or where I should even start in terms of diagnosing? I'm sure someone's had this issue before but I haven't been able to find anything online relating to this specific issue, most of the issues are with the seals leaking or the motor failing entirely. Thanks in advance!
    • Do you have some data like fuel pressure? It's really hard to say if you're still fighting a fuel system issue at this point. Could be something weird like the FPCM dipping out.
    • Yeah in that case, pulling the dent out. Event a very slight dent can create a lot of work filler-wise and there is a strong chance the panel won't be the factory shape when you are done (as the dent will result in a new high point created somewhere, then everything is brought up to that new high point... but the panel shouldn't be that high if that makes sense).  So you've filled and primed the panel and it is flat, why would you go back and remove the primer and add more filler?
    • Something else I have been faffing with while the car was off the road is making the AC work. Assuming the car isn't at a thermal limit the idea of having AC while waiting in line to go on track sounds delightful. I have actually been lugging around the weight of the entire system since 2018 when the RB25NEO went in without it working at all.  The main reason was in the first few events before I got around to re-gassing it the rubber hose that runs under the manifold had the factory heat wrap/sleeve fail resulting in this: ~2 years ago I purchased a complete used R32 AC line set but when I finally went to install it the line i needed was different where the expansion section is I found a local place that was able to replace the rubber section and re-crimp. They also added some modern heat sleeve to the hose Tight fit but fingers crossed this is the last physical piece of the puzzle needed
