iv had it with the weather now! i washed my car before and not one drop of rain while i was washing it,i just finished shamying the entire car and was about to put it under the carport when it just randomly poored with rain and soked the car again!! :banana:
Im tired, been at autosalon all day kicking rude people off our display, can't you see that it's roped off? geez. the graham west dyno has low balled everyone, mine only made 165rwkw :banana:
bout time those autosalon dyno's were realistic.
bahahahahahhaa
Hey guys, i need to find these four connections on my ECU. Ive never touched the wiring on my ECU before and just wanted to make sure that i have the right wires.
I need:
+12V Ignition Switched pin
Ground Chassis 0V
Oxygen Sensor signal
Airflow Meter signal
Now ive found this ecu diagram pinout
Now im pretty sure that for the 12v ignition switched im looking at pin 45, and for Ground 0V im looking at pin 10 or pin 20. (Please correct me if im wrong)
Airflow meter signal is pin 27.
Im not sure where the other pin for oxygen sensor is. I found another ecu diagram with the oxygen sensor on it (Pin 55) but im not sure as the diagram above says 55 is nothing =/ I know how to check these with a multimeter but i just wanna make sure first =)
Im tired, been at autosalon all day kicking rude people off our display, can't you see that it's roped off? geez. the graham west dyno has low balled everyone, mine only made 165rwkw :)
It's Mainline Dyno's are more accurate to real HP than the dynodynamics ones. Everyone is in the same boat though and it also makes "SLO 33"s 465kw more impressive, It would be more like 510kw on a DD dyno.
Edited by D_Stirls
    • Seems like a decent result for a modded JZX110. They are bulky in comparison to the 100 and 90 models (which I'd prefer myself) but they are getting very few and far between here in JP these days. Thanks for the detailed review and the import process into the UK. I also have a car which I'm hoping to export from Japan at some stage so it's good to know if someone from the UK was interested in it. By the way the corrosion underneath is par for the course for cars which were located in/near the mountains or along the Japan sea coastline. They get huge amounts of snow every winter and the sodium chloride is used on the roads. Many cars have some kind of rubber like treatment underneath but they tend to limit it to the wheel arches underbody and fuel tank. Suspension arms and sub-frames will have similar corrosion to your JZX110 which is a common sight. See it all the time and car dealers here generally don't even mention it unless asked.
    • If the sound goes away when you clutch in, the 1.5/2 way diffs are just shit, and you are a normal person. The diff is likely "fine" but driving at anything under 30kmh is a violent horrible experience. It would be exaggerated with solid diff bushings and subframe bushings if you have those.
    • Trailer got new mudguards to accommodate the new wheels Lightweight ally Painted, stickered and done ✅ 👌
    • Did you hit up the search function? R33 and greddy and cable returns this thread with some options.   https://www.sau.com.au/forums/topic/358214-rb25-throttle-body/
    • Thanks buddy.. the standard one needs to be about another inch or inch and a half longer. Thanks anyway
