Had some 40-something daddy wanting to drag me off at every set of lights with his 'TRD edition' Aurion this morning.
I think he was getting more and more irritate the more I ignored him :rolleyes:
i hear this, i think everytime an aurion has pulled up next to me they have wanted a race. i think the 200 kilowasps propaganda goes to their heads
Staying in tonight (no money, saving it all :rolleyes: ). Just came home from work, also bought new work shoes today which I'm stoked about. The other ones were falling apart.
Going out for a drive before Uni tomorrow, probably around the north to check out the Port River bridge and the Northern Expressway progress.
well tonight has turned out to be interesting.
i was watching the men's hockey bronze match (we won btw) and i heard 2 loud thumos.
next thing my sister comes in and tells me some1 ran into the paddock across the road
they took the fence out, hit a tree, and in his escape reversed into another fence then as he took off
almost ran over my dad and brother. didn't have his headlights on :rolleyes:, dad managed to get his number
plate so hopefully the cops catch up with him.
oh we also have the fire fighters out :), coz there was heaps (of what we thought was) acid
on the road, it smelt pretty bad, but yeah they said it was just water, luckily.
how much did you pick them up for? i think jis sells those dials as well!
anyway i was at a traffic light on torrens and woodville rd i think and there was a vy ute doing donuts in the middle of the intersection till the other lights went green :rolleyes:
    • Before all the EFR fan boys come in, have a look at: https://www.garrettmotion.com/racing-and-performance/performance-catalog/turbo/g-series-ii-g30-825-58mm/ It also comes in a T4 1.06 divided housing. I would dare say if you want response & also decent power, this thing would chop.   AND apologies, just re-read your post, you've already bought the turbo... whatever you do, make sure you stick with divided housing and proper twin scroll manifold.
    • People have got to stop doing that. ShatGPT is not a search engine. It is a hallucination factory.   I also would recommend the 1.05. The .83 will "work" for you , in that it will be more responsive, but I think you'll find that it won't be anywhere near as good running it out to 8000rpm as the big housing will be.
    • Decided for the first time ever I would tow my car TO the track day on the same working theory as bringing tools and spares "if I have it I wont need it, but if I leave it behind i will 100% need it" all setup and ready to go out and try these A050 for the first time First session showed I needed to stiffen up the dampers a touch but still managed a few 1:21's without much effort. things were looking good. Came in a dropped the tyres down  to 26/28 as they had gotten to 35/33C from 22C cold The first lap of session two I managed to drop into 1:20's. Then in the second lap into the second session. Coming into T3 and I suddenly lost brake pedal followed by some huge rear end vibrations and scraping sounds. Got it back into the pits after session ended and found this. in the attached video, all of the wobble is in the hub its self, wheel is mint, and bearing feels tight. lKXLqpd - Imgur.mp4   Deciding it was a bent spindle I tried to find bearing/hub assembly locally but was unsuccessful so it was loaded back onto the trailer i luckily brought it on to drag it back home
    • 1.05 you’ve gotta let it breath
    • You have to continuously fill it to avoid dry running. Personally the transmissions I've serviced have never been bad enough to justify doing this because it is definitely a pretty complicated and somewhat risky procedure compared to simply draining the pan, measuring what came out, then refilling with the exact same amount.
