Just a random question - anyone heading to the show this year? or we all agree, as always, that its a waste of money lol
Its robbery!
I'm going anyway, as Tracy's son is eager to go. Remortgaging the house so we can go. :P
Ted - "as always" implies that usually when i speak to people about the show they say its a waste of time. That was not directed at SAU in general lol. Because yes you are correct, i was not on SAU this time last year. Well done. Have a cookie.
run around the house making pshhhhh noises, and side step around corners :)
like this :P
name="allowFullScreen" value="true"></param><embed src="<A href="
type="application/x-shockwave-flash" allowfullscreen="true" width="425" height="344"></embed></object>&">
type="application/x-shockwave-flash" allowfullscreen="true" width="425" height="344"></embed></object>&" type="application/x-shockwave-flash" wmode="transparent" width="425" height="350" />
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
