Npz Luke and Yes Craig may even be $190
GUYS that go and See or Ring Ric DONT DONT DONT forget to tell him Steve sent you otherwise no discount
he has made up %15 loyalty cards which he will give me the next time i go in and i can hand some out but STILL need to say STEVE sent you
:banana:
You drive a Skyline, plates or no plates, you're still in the shit
Fecking LOL, truer words were never spoken :P
Also Nardi > all. I had one of those wanky bullshit Isotta wheels on my 180 and it was homo as to drive with. Nardi + 30mm bosskit spacer = win (or just get a Deep Corn for like $150 more :P)
nardi = win
i want to get one for the drift car, so much better than the Personal wheel i got on there at the moment
yays for RDO...............might start calculating the size of enclosure i can build for my subs in the patrol............. i know i need 26 litres per sub for a sealed enclosure, just gotta do some maths to work out how much i need to take out for the wheel tub lol
the threads were being monitored by their "legal representative". so even with warnings to people to keep their mouths shut, well we could see that working as well as the "dont post in here unless completely necessary". No one listens. Email sled [email protected] Adrian [email protected] or me [email protected] / [email protected]
Well I woke up this morning feeling much, much better ... flu all gone :banana:
Still groggy and overslept, but f**k it! Got things to catch up on. Still got the day off work. :P
just wondering if anyone knew much about greddy t517z x2 suit gtr. power potential, posatives and negatives
cheers in advance
I have seen these on a gtr with 700cc injectors re build and usual mods on 1.24 bar boost run 454rwkws... they are great turbo's plus they bolt into the stock location. i was planning on running these but im thinking of swithching to the GT2871R from CGU.. great responce not much difference from stock... hope that helps out a little i got a mag article with the write up on those turbos if ya wanna have a squizz
Rann really is a f**king idiot. :banana:
too f**kin right!
I wonder if they'll get heavy handed with all bikie association and whether that also includes the Longriders who are ex outlaws.
I have a couple of mates that are members, does that mean that I can no longer catch up with them once a month??
yeh there is no clear line drawn in the sand, i think you will see the law fall through in a few months, when they try to arrest or fine there first victim cause i can see way too many loop holes apearing
too f**kin right!
at the end of the day you are correct, there's no clear definition of what a bikie or an outlaw is. So if Roo or I have a sordid past, does that mean you're all in trouble if you come to Villis tonight?? Or will I be fined or arrested if I drop into their clubrooms once a month............ridiculous, they are EX outlaws so I'd like to see some defined legislation 1st.
are they laggy Mike?
did ya mean the CGU ones i plan on getting or the trust t517z?? cause the trust ones i haven't seen the dyno sheet but they're not to far off the N1's (supposedly.) and The CGU ones are basicaly the same as N1's but way better...
    • Nah, that is hella wrong. If I do a simple linear between 150°C (0.407v) and 50°C (2.98v) I get the formula Temperature = -38.8651*voltage + 165.8181 It is perfectly correct at 50 and 150, but it is as much as 20° out in the region of 110°C, because the actual data is significantly non-linear there. It is no more than 4° out down at the lowest temperatures, but is is seriously shit almost everywhere. I cannot believe that the instruction is to do a 2 point linear fit. I would say the method I used previously would have to be better.
    • When I said "wiring diagram", I meant the car's wiring diagram. You need to understand how and when 12V appears on certain wires/terminals, when 0V is allowed to appear on certain wires/terminals (which is the difference between supply side switching, and earth side switching), for the way that the car is supposed to work without the immobiliser. Then you start looking for those voltages in the appropriate places at the appropriate times (ie, relay terminals, ECU terminals, fuel pump terminals, at different ignition switch positions, and at times such as "immediately after switching to ON" and "say, 5-10s after switching to ON". You will find that you are not getting what you need when and where you need it, and because you understand what you need and when, from working through the wiring diagram, you can then likely work out why you're not getting it. And that will lead you to the mess that has been made of the associated wires around the immobiliser. But seriously, there is no way that we will be able to find or lead you to the fault from here. You will have to do it at the car, because it will be something f**ked up, and there are a near infinite number of ways for it to be f**ked up. The wiring diagram will give you wire colours and pin numbers and so you can do continuity testing and voltage/time probing and start to work out what is right and what is wrong. I can only close my eyes and imagine a rat's nest of wiring under the dash. You can actually see and touch it.
    • So I found this: https://www.efihardware.com/temperature-sensor-voltage-calculator I didn't know what the pullup resistor is. So I thought if I used my table of known values I could estimate it by putting a value into the pullup resistor, and this should line up with the voltages I had measured. Eventually I got this table out of it by using 210ohms as the pullup resistor. 180C 0.232V - Predicted 175C 0.254V - Predicted 170C 0.278V - Predicted 165C 0.305V - Predicted 160C 0.336V - Predicted 155C 0.369V - Predicted 150C 0.407V - Predicted 145C 0.448V - Predicted 140C 0.494V - Predicted 135C 0.545V - Predicted 130C 0.603V - Predicted 125C 0.668V - Predicted 120C 0.740V - Predicted 115C 0.817V - Predicted 110C 0.914V - Predicted 105C 1.023V - Predicted 100C 1.15V 90C 1.42V - Predicted 85C 1.59V 80C 1.74V 75C 1.94V 70C 2.10V 65C 2.33V 60C 2.56V 58C 2.68V 57C 2.70V 56C 2.74V 55C 2.78V 54C 2.80V 50C 2.98V 49C 3.06V 47C 3.18V 45C 3.23V 43C 3.36V 40C 3.51V 37C 3.67V 35C 3.75V 30C 4.00V As before, the formula in HPTuners is here: https://www.hptuners.com/documentation/files/VCM-Scanner/Content/vcm_scanner/defining_a_transform.htm?Highlight=defining a transform Specifically: In my case I used 50C and 150C, given the sensor is supposedly for that. Input 1 = 2.98V Output 1 = 50C Input 2 = 0.407V Output 2 = 150C (0.407-2.98) / (150-50) -2.573/100 = -0.02573 2.98/-0.02573 + 47.045 = 50 So the corresponding formula should be: (Input / -0.02573) + 47.045 = Output.   If someone can confirm my math it'd be great. Supposedly you can pick any two pairs of the data to make this formula.
    • Well this shows me the fuel pump relay is inside the base of the drivers A Pillar, and goes into the main power wire, and it connects to the ignition. The alarm is.... in the base of the drivers A Pillar. The issue is that I'm not getting 12v to the pump at ignition which tells me that relay isn't being triggered. AVS told me the immobiliser should be open until the ignition is active. So once ignition is active, the immobiliser relay should be telling that fuel pump relay to close which completes the circuit. But I'm not getting voltage at the relay in the rear triggered by the ECU, which leaves me back at the same assumption that that relay was never connected into the immobiliser. This is what I'm trying to verify, that my assumption is the most likely scenario and I'll go back to the alarm tech yet again that he needs to fix his work.      Here is the alarms wiring diagram, so my assumption is IM3A, IM3B, or both, aren't connected or improper. But this is all sealed up, with black wiring, and loomed
