yeah i agree mate, i wouldnt use one, unless i absoloutely had to!
when are you down this way next?
ill be down south on friday for work, seaford is as far as i go, round 1-ish
or ill be home round 2 everyday
Rode my bike thru a less-than-favourable suburb this morning. Shoulda seen all the scum staring at my MV Agusta, calculating in their little thieving minds how they could steal my bike.
Ferals :)
yeah, im gonna take the 25s off, and drive it down to wheelworx on saturday now,
ill ask for a test fit on the 15,
i want them to look good, but not rub, i want the best of both worlds :)
From the pics it looked like you could get away with the 25s on the front. 245 is a pretty big tyre for fronts, you could go down to a 225 and give that little bit more clearance. That way you'd have the rim sitting where you want it and more room so it doesn't scrub.
i dont like that much offset on the front, looks like a go cart imo
and i know 245s are quite large, but its what come with the rims, and they are brand new, so
i dont really see much point in changing them,
ill be up north tomorrow eavning, ill msg you after i finish work to drop off the form if its not to late otherwise im sure we can sort something out.
i have 255x8.5 and can go wider fatter :blush::)
    • Not really, but the heater box is pretty simple mechanically....if the door is one way the air bypasses the heater core and if it is the other way it goes through it for warm air.  If you are sure the actuator you moved manually is for the heater mix (there would also be one for output air direction) then I'd take the heater box out and see what is happening (you'll have to regass and re-coolant the systems afterwards) BTW pp724 onwards from the GTR workshop manual cover the system in good detail, it is probably worth checking. I think the IAT sensor might be a problem electrically for getting cold (if you got 24 error code not -24 it thinks the incoming air is -50c) and it covers how to test the sensor (although most likely it is either not plugged in or a wire is damaged)
    • Use the GKTech subframe bush and bring your subframe 10mm closer to the chassis. You'll need to fix an exhaust hanger to suit. One of the best mods I've done.
    • You'd really have to pull it apart further to know, it least you can be confident that the one heading to the back is not connected any more. There was once a ground on the shifter seal mount too, your head unit issue could be that simple
    • Perfect, I'll get to it this winter then at the same time as I weld on my anti squat kit.
    • Alright so my 32 only has one temperature no matter what degree you set it to. I’ve tried disconnecting the servo motor arm and moving it either direction and got no change. I’ve fixed the leak in my AC and re charged it and with it on and clutch engaged it still blows hot even though the low pressure pipe going to the firewall is ice cold. Both heater core hoses are hot while running as well. Diagnostic code showed 24 for intake air temperature sensor. Anybody got any ideas?
