sure your not on drugs :):blush:
btw i have a R33 standard turbo your welcome to check out
cool steve, wat you looking to get for it?
why the choice of a gt 30/40 ryan???
what size exhaust housing you gonna choose??
still not sure as to what im gonna do yet with the rest but i like your set up.
maybe i should up grade to a gt35/40 and sell u mine but you'll have 2 go external gate and maybe change to a .63 housig to reduce lag
ive got a rb25 exhaust housing machined out for a gt 30/40 exhaust wheel for a internal wastegate setup still if u want it
steve im going to be selling my nismo 555 injectors real soon if u still interested as i have ordered new bigger sard one's
25 rear housing with a compressor that size isnt' really what im after...they rear tends to work too hard and they get too hot....If your interested in selling your 30/40 i would get an internal gate with a .63 rear fitted. Im very interested mate.
hmmmmmmmmm ill get sum prices tomorrow on the gt 35/40 and get back 2 ya
how much laggier will it be??
Nah they are a different body shape on the JZX110 chassis. You been on JZX100.com lately? Theres a picutre thread on there.
nah have not been on htere in ages... i have a look occasionally to check my "flame the nissan driver" thread :)
i'll have a suss
Sled, did you sus out whats going on the the 98 octaine fules yet??
just wondering ahead of my fe fill this tuesday.. =)
Sorry Luke, I did the whole Father's Day thingy yesterday with my Dad and my kids and since then I've been flat on my back with a bulging disc.
If I can get into the car at some stage I'll go and see the local BP.
your up till 1.30 nothing wrong with you doing a bit a e-search
JZX-100 FTW 1JZ chaser
    • Ok I get you. But isn’t the butterfly intake a headache with the +T?  see this is my plan so far but please advise me into the right direction.  Nistune Ecu, 1000cc Bosch injectors, TD05 or TD06 Kinugawa turbo using stock rb25det exhuast manifold, walbro fuel pump unsure of model I think it’s 450/460, spitfire coils and sparks to suit and a R35 MAF sensor and boost sensor.    I was thinking maybe do a cheap eBay plenum $400-500 or try find a stock det neo intake. I think I’d port match it so it’s getting the full capacity but open to advice please.  Thanks
    • The issue now is the 'fuel cut' while driving, and when it happend, it does not stall. This, I did not test the fuel pressure while driving as I cannot with a fuel pressure gauge. I do have Nistune logs, yes. I have also replaced the MAF Sensor.   Also related to the FPG Fuel Hanger – I just realized that I need a Deutsch Crimp Tool to crimp some cables for the FPG Fuel Hanger. Need to purchase additional cables as the kit only included 2, which are for the float. FPG has not responded to my emails so far since purchasing. I thought about taking it to someone and having it done professionally, but I am reluctant since everyone I took it to messed up in some way.
    • There's a good German place in Brisbane if youre up for the drive 😛
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
