if no-one has posted about this, they're the guys that run the inspection stations out on the side of the highways, plus they also have rights to pull over and issue defects to heavy vehicles and taxis
these pricks were running round town one night, they'd finish with one cab, bolt round the corner, throw on the purple lights and do another one :)
and on another note, my internet speed :P - bigpond cable internet (same cable as foxtel uses :) )
Too slow
321636669.pngFTW. A bit slow because the wife and kids computers were playing games when I did this.
Edited by 4door_Sleeper
ye man it keeps coming up with an error when i try n sign in :P
i clicked the trouble shoot and it fixed it through its steps try that 1.
on another random topic :) does anyone know of anyone thats had a non convertable car turned into a convertable or workshops that do it?
i heard its easy enough if you gota steel chassis but is that the only reasonable way?
to below yeah that is pretty low but i only got 5827. its quick enough for sau purposes :) learn some patience people the porn will download eventually
Edited by Inline 6
hey just wondering does anyone know if anyone in adelaide does RB20 ecu remaps??
been thinkin bout gettin one when i get my 32 back
Mike Dale from Road & Track can do any remap to any nissan ECU as well as a safe and reliable tune (or if you specify it, a dangerous hardcore performance tune). give them a call. info is in my sig.
+1 from a happy customer...I'll be getting a stock 32gtr ecu modded once I get the turbos and supporting mods... and best thing yet, I'll still be able to do data logging/live telemetry/consult diagnostics/ecu map fine tuning with a nice conzult cable/software kit :) Got the EEE, wired it into the glovebox... just need the conzult kit. +2 for solid state hdds and their tolerance to vibration and gforces :P
-D
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
    • So M12 and sealant should be fine?    NPT ” because that’s what I had and what I could get atm.
    • Wouldn’t touch par if they gave it to me. You need to ask how much power you’re looking to make and then add about 50% to it because that’s what you’ll end up making  The factory box says no more at about 350kw or so, the upgraded synchro boxes won’t handle much over 500kw for long and at that point you’re looking at an auto or dog engagement manual,  once you’ve gone dog engagement you may as well go sequential, they cost a little bit more but it’s worth it  also while you’re at it you should upgrade the transfer case with 10 friction plates
