if no-one has posted about this, they're the guys that run the inspection stations out on the side of the highways, plus they also have rights to pull over and issue defects to heavy vehicles and taxis
these pricks were running round town one night, they'd finish with one cab, bolt round the corner, throw on the purple lights and do another one :)
and on another note, my internet speed :P - bigpond cable internet (same cable as foxtel uses :) )
Too slow
321636669.pngFTW. A bit slow because the wife and kids computers were playing games when I did this.
Edited by 4door_Sleeper
ye man it keeps coming up with an error when i try n sign in :P
i clicked the trouble shoot and it fixed it through its steps try that 1.
on another random topic :) does anyone know of anyone thats had a non convertable car turned into a convertable or workshops that do it?
i heard its easy enough if you gota steel chassis but is that the only reasonable way?
to below yeah that is pretty low but i only got 5827. its quick enough for sau purposes :) learn some patience people the porn will download eventually
Edited by Inline 6
hey just wondering does anyone know if anyone in adelaide does RB20 ecu remaps??
been thinkin bout gettin one when i get my 32 back
Mike Dale from Road & Track can do any remap to any nissan ECU as well as a safe and reliable tune (or if you specify it, a dangerous hardcore performance tune). give them a call. info is in my sig.
+1 from a happy customer...I'll be getting a stock 32gtr ecu modded once I get the turbos and supporting mods... and best thing yet, I'll still be able to do data logging/live telemetry/consult diagnostics/ecu map fine tuning with a nice conzult cable/software kit :) Got the EEE, wired it into the glovebox... just need the conzult kit. +2 for solid state hdds and their tolerance to vibration and gforces :P
-D
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
