Just trying to read up on it now, One report says a broken back, another just says damaged his spine... i guess we'll have to wait and see what they say tomorrow. There's pics of it if you Google his name.
This is what one of them say...
CHANNEL 7 star and V8 Supercar driver Grant Denyer is recovering in hospital after surviving a serious accident during a monster truck show stunt.
The diminutive Denyer - made famous as Sunrise's weatherman - was trapped under his 6.5 tonne super-sized truck at Dapto after it flipped during a demonstration for a Monster Truck Championship to be held this weekend.
Denyer suffered suspected serious back injuries and was rushed to hospital this afternoon.
"Yes, he was in a monster truck crash and has been taken to hospital," Seven news and current affairs chief Peter Meakin said.
"The injuries were thought to be serious, and he is being kept in hospital for the time being.
"But from what we've since been told we believe he is going to be OK."
Meakin said Denyer, 31, was not on duty for Seven but competing in a monster truck sport event.
"Grant has been involved in the sport and motor racing for some time," Meakin said.
"But this caught us by surprise and and we're just hoping and praying the injuries are not as serious as first thought."
Denyer - who could not be reached for comment - was expected to recover enough for an interview on Sunrise tomorrow.
Ohh, and 1 more thing, if you think that your Super will see you past retirement, you're dreaming. Unless your a politician with a $2 million package waiting for you, you've got no chance. In 10 years the average price of a house will be close to $1 million, by the time you retire that figure will at least quadrupple.......you'll be lucky to buy a new car with your Super money.......so get smart and start planning now.
haha, funny how we were only discussing this the other day........biggest insurance company on the planet AIG with over a trillion $$ in assets needs the help of the US Reserve so it doesn't go belly up while all the fat cats upstairs that treated Wall Street like a Casino walk away millions $$ to retire on.
Still think Super is the way to go for retirement?..........maybe property investment ain't a bad idea after all.
anyone know mark denyer (former sunrise weather guy) he broke his back today trying to jump a monster truck over 6 cars... poor guy :)
so Norman Freeman dieing is nothing to worry about
um can you say lag monster Ryan will leave nice trails but :)
it wont be as laggy as you think, with a .63 rear and a machined out wastegate, We have exactly the same turbo on my mates RB20 and thats driveable lol......wait n see. Plus im over too much response....too much wheel spin straight up gets a little old.
Edited by Ryanrb25
then it wont be any gd 4 the hills then will it?
im not game, your cars is going to be a weapon.
dw man yours will be a weapon too :)
Woooo just got some insurance quotes for the vehicle I'm looking to purchase.
$654 a year for full comp :):blush:
Can't bloody wait to have a normal car, so over shitbox hoon cars :)
whats that for
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
    • For race cars, this is one part where I find having the roll cage bar having gone through a hole in the floor better than the build it up on a ledge inside... The Merc I help on, the main hoop ends are marked on the car, and the jack is marked... Jack goes under a few inches and lifts one whole side of the car up... Removes that fight for long slim jacks for race car duties!   My biggest issue for the daily drivers I work on, is my jacks don't go high enough. The jacks start out on a few blocks, jack it up, then start a second jack under it on more blocks, and then I can get an axle stand under it. My axle stands are presently in use, and are nearly fully extended. The car is sitting with barely more than a cm of clearance to get the wheel off the studs! Sarah's Kluger is the same, as it has an ungodly amount of droop available in the suspension and a distinct lack of good jacking points!
    • Happy? Yep, my to do list is getting shorter and shorter. Either this light approaching is the end of the tunnel, or I'm about to be hit by a train... Ha ha ha   Also, Duncan isn't that far out of town that you need to make a multi day drive out of it. 😛
