Ok a little random, but thats what wasteland is for. Was talkin to Heslo and few others on saturday night about a 'ghost tour' I did of the old adelaide gaol not too long ago, and few of us are keen to do it again. Its $20 and goes for maybe 2 hours or so. I had paranormal investigators as my tour guides, they were awesome, and i love this stuff, yet they still got me pretty freaked out!
So yeah anyone else be keen? I need a minimum of 15 people to make a booking, and im pretty sure they do it on the last friday of every month.
hey
lauren and i would be down for this
so i got my speedo working tonight woo, kinda forgot to plug the sensor back in while changing gear box oil :P
Nardi wheel is on to :)
Now just need to rise the front abit, and fix a hissing noise in my speakers.
wouldnt mind going for a hillzy right now, if only.............
yeh me 2.... if only haha
hey boys, i know what your hinting at lol
good things come to those who wait...adrian is priority one
craig your on thursday if you want? instead of friday (your bday)
sam came up for a visit on sunday, was good to catch up considering i never get the chance to.
yeah man, was good to catch up with ya! mannum is so chilled out after leaving the traffic jams in the city.
those pics are a reminder to me that i need bigger wheels :P
Sams car always looks good, and tim yours is, wow. Lovin your car
thanks flick :)
+1 on tims car, looks tough as with the wide guards and huge rims!
Edited by Sambo33
hey Ryan, can I get in line as well.
I tried ringing you a couple of times but you were obviously busy.
Let me know when's a good time for you.......cheers
    • Not really, but the heater box is pretty simple mechanically....if the door is one way the air bypasses the heater core and if it is the other way it goes through it for warm air.  If you are sure the actuator you moved manually is for the heater mix (there would also be one for output air direction) then I'd take the heater box out and see what is happening (you'll have to regass and re-coolant the systems afterwards) BTW pp724 onwards from the GTR workshop manual cover the system in good detail, it is probably worth checking. I think the IAT sensor might be a problem electrically for getting cold (if you got 24 error code not -24 it thinks the incoming air is -50c) and it covers how to test the sensor (although most likely it is either not plugged in or a wire is damaged)
    • Use the GKTech subframe bush and bring your subframe 10mm closer to the chassis. You'll need to fix an exhaust hanger to suit. One of the best mods I've done.
    • You'd really have to pull it apart further to know, it least you can be confident that the one heading to the back is not connected any more. There was once a ground on the shifter seal mount too, your head unit issue could be that simple
    • Perfect, I'll get to it this winter then at the same time as I weld on my anti squat kit.
    • Alright so my 32 only has one temperature no matter what degree you set it to. I’ve tried disconnecting the servo motor arm and moving it either direction and got no change. I’ve fixed the leak in my AC and re charged it and with it on and clutch engaged it still blows hot even though the low pressure pipe going to the firewall is ice cold. Both heater core hoses are hot while running as well. Diagnostic code showed 24 for intake air temperature sensor. Anybody got any ideas?
