i dont like hot stuff, its the exit i worry about more than the entry.
The 'exit' is just a reminder on how good the stuff is :/
I like hot foods. Its almost guaranteed no one will touch my food when I'm not looking :dry:
yeah the hotter the better. if my eyes arnt watering.. FAIL!
Takes a bit for water my eyes ... but when I tried this stuff, WOW!
The GF literally asked "is it hot enough for you?" ... my reply was "wow!", and I bought a bottle immediately :dry:
If it doesn't make you want a drink badly, then it ain't worth buying imo.
I got some really hot smallgoods at home, like spicy cabana!
You should try some chilli sauce I got at home :dry: Its rated 10+/10 = nuclear grade chilli :/
Its not called 'Ass reaper' is it? Theres one in the states, my uncle used to use it to play jokes on people, like putting this atomic hot sauce in peoples mouths while they were sleeping....
Ruby u should come have a tindaloo sometime.... Harvest of India, oconnell st heh
-D
