snapped a bolt in the f**king shit ass just jap cooler were the brackets mount coz the crap quality SHIT..
did the same on mine when i tightened the bolt up. its not the cooler thats shit quality, its the bolts they supply
lessons learnt when buying cheap stuff, always replace the bolts with good stuff
morning all :)
one more weekend till i can clear out my wardrobe and put all that damn stereo gear into the patrol :bunny:;):D
Can someone who has a R32 or 33 Manual do me a favour?
In the Service Data and Specifications for the braking system (at the end of the Brake section) there is a Split Point in kPa and a reduction ratio in the Data for the Brake Master cylinder. For the S13's it's: 3.932 (39.2, 40, 569) x 0.4.
Could some one let me know what they are for either an R32 or R33.
Thanks
took my turbs off, turns out its a hi flowed vg30.
good nic too.
captain thread comes out monday, then i gotta put it all back together....
GO THE HAWKS!
checking shaft play is only half of the story about telling whether a turbo is in good nick or not, Another way of checking is actually looking at the whole rear wheel of a turbo, a mate recently bought a gt3540 off a typhoon from ebay, shaft play was in top shape, and the wheels looked fantastic, Taking the rear housing off told a different story. The whole rear of the wheel was chewed away leaving a very f**ked turbo. from the outside the wheel looked to be in top shape. Obviously your is fine craig lol i just wanted to tell a story lol.
    • UPDATE: Yes the GSP Axles are compatible. I installed it on my R34 today and they are working a treat! Turns out that the S13, S14, S15, and 200 SX all used the same axles as the HR34, and ER34 NA models. Which is 2 bolt x 3 pairs.
    • Also build this EH ute with 370z motor and gearbox with a couple of turbos just for fun.
    • Got the passenger door on plus the master cylinder and booster. Loaded up to take it home. At home, the colour changes a lot in the light.
    • Nothing cheap, but I have seen the AC Hydraulic DK13HLQ which is pretty close to what you're asking for. The problem is the hydraulic cylinder mandates that the back of the jack be a certain height and Skylines have fairly deep inset floor jack points. A more certain and cheap option is to get some nominal 2x10 inch lumber boards and have one board be 1.5 feet, the other board 3 feet. Glue it all together with lots of clamps to maintain pressure. Make two of these. The ramp suggested above is a good idea, it takes quite a bit of clutch slip to get over each of the boards. I only need the first ~1.5 inches for my low profile jack on a standard ride height car but a lowered car you want to go up to the full ~3-3.5 inches. Paint it or store indoors if you want it to last.
    • Ok. And Nistune? I read (here too) mainly on Stagea threads that it can by "turn off" with Nistune. But they say they still had the sensor plug in. Next week iam going to the Nistune(and other ECUs) tuner so i can finally make it work. I drove the car home and apart from the cut it drove great. No misfire no smoke no hesitation or rough start...so hoping it is this sensor that is missing
