lol ryan,do we wanna know how you know how to do that :wacko: lol
eddy, ryan pretty much knows everything about everything most times so more than likely he will be able to figure it out. Hopefully its something small.
there could be so many police out today coz it's the SANFL grand final today
coming home from town today a heap of cops flew down south road and by heaps... 5 bikes, 5 patrols, 2 detectives and a paddy wagon
anyone know what happened?
Nope, that being said, I've been at work so I haven't had a chance to try and fix it today.
Nothing. I have to use the key to get in because the central locking isn't going (The remote is fine), then when I turn the key in the ignition nothing happens. I've checked the battery and connections and that's fine and so are the fuses so either it's either the starter motor or the immobilizer screwing up.
Are you saying no electrics work?
An immobiliser may effect your central locking (but i wouldn't have thought so) but if you have no other electrics in the car I doubt its the immobiliser and certainly not the starter motor.
Can you get your alarm to activate? interior light or headlights to work? hazard warning lights? (an immobiliser shouldn't stop all of these from working and will indicate the problem is instead between the battery and the fuse box)
You said you checked out the battery - but it might be worth trying another one if you have one handy, or try a jump-start.
I would also be checking the battery terminals (you wouldn't be the first to have corrosion in the terminal cause a problem like this)
Not sure if the 32 has a fuse in the main battery line (some cars do) or a big spade fitting that has corroded (took me a while to find this problem on an old valiant once)
    • A few suggestions: Do you have the option of retarding your exhaust cam gear to bring the power band over to the left? VCT would be turned off after you make peak torque, you see the power/torque will decay faster with it left on all the way to the limiter Once VCT is turned off, you'll find the motor will take a bit more timing being ramped in Send its mum, more boost! Of course, depends on your exhaust pressure.
    • Tow a boat... people won't know wtf is going on 🤣
    • I was back on the dyno again yesterday after completely revamping my methanol injection system. I was making 440kw at 19psi. Great, this is more then I was making last summer with my old meth system at that pressure, and I figured it would be smooth sailing up to 30+psi. We continued increasing from there and by 25psi, I had only hit 455kw. Dyno sadly lost utility power at this point and I left. We seemed to be on course to hit the same power wall as last summer (477kw@27psi). This is a built RB25 S1 stroked to a 2.8. Built and ported head with Kelford 272/262 cams. Precision 6466 Turbo. Tuner last year believed the power wall is a mix of RPM limitations (Hydro lifters/Limit set at 7600RPM) and fueling. With my new meth system, we're seeing zero knock now but it still won't go up.  What else can I do at this point? Here's my train of thought.  - It's clear from the dyno graph that I would easily make power to 8500+RPM but I'm limited to 7600RPM. I could risk increasing my limiter, but hydro lifters have me worried. What are my options here besides going NEO head or solid lifter conversion? I'm rocking a 1.05AR turbine on my 6466. Would dropping down to a .84 help shift that power down in anyway? - We're only seeing roughly a 30kw difference at the top end with VCT on or off. Is this normal? I want to confirm VCT is working properly. - Should I look into other cam options?  - Should I just keep increasing boost and see if she wakes up later on? I would expect to hit 600rwkw around 35psi with my 6466.
    • First thought is to use a ram mount (to hold the ipad) + windscreen suction mount. The arms on the ram mount can be as long as you like, should be able to position the ipad pretty well with that setup.
