You start to get more philosophical as you get older, yesterday i realised that getting married is very much like going to a restaurant with friends.
You order what you want, then when you see what the other person has, you wish you had ordered that.
well well well the school kids are back in town
and woman wear white because they are pure and boys wear black cause they aren't
and most kitchen appliances these days are stainless steel you goobers :bunny:
thats if not the funniest thing you have said ever :bunny::(
are u implying that black people are impure <:|
on the other hand
all i need is a woman coated in stainless steel, then I got myself a perfectly color co-ordinated designer label kitchen. hell yeah. that'll impress the chi... er... well... it'll impress me. maybe I can put some spinning rims over her metallic bosoms
-D
what the hell is with this crap
http://i33.tinypic.com/sq0eh4.jpg
ever since my mate browsed sau on my pc its coming up and its really annoying the shit out of me :bunny:
In the top Right hand corner of the thread click the "options" tab then click "switch to standard"
-D
I think they have gone to stainless simply because its more expensive.
My son asked me the other day, "Dad, how much does it cost to get married?"
I had to be honest and tell him, "I don't know son, I'm still paying."
By the way, do you know the substance that has the power to parallyse a woman from the waist down - for life?
Its wedding cake.
The thing I find confusing with women is that even when you do what they ask you you still end up in trouble. I once had a girlfriend told me I should be more affectionate. So I went out and got two other girlfriends - she hasent spoken to me since :bunny:
Its wedding cake.
f***in LOL !
thought would give you guys a look forthose interested, small vid of me, matty and another mate at mallala saturday just gone for drift prac. Highlights, matty cleans up the tyre stack at turn 1 an i do an awesome parking job lol.
Enjoy.
http://au.youtube.com/watch?v=0iQqJGR-zYw
bit dear wait till next year and get one local for $150k
not the way the $AU is going Steve................you may have to add another $50K to that price by then..............not to mention the luxury tax has gone from 25% to 33% now, thanks to Rudd
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
