f**k all.
i see your point.
doesnt mean they wont bend you over when it comes to payment time.
Well it does take a fair bit of time, Tilbrook says 8 hours and Southern Hi tech said 10 hours, and thats for turbos only, so it must be a fairly hard job.
Try yourself Chad, I know I'm gonna attempt to do mine!
Im way to lazy, so i'll give Tilbrook a call and see what he's upto these days, when he shut up shop he said he would still work on my car, and at a discounted rate :)
:D Ask Heslo about PK's cocktails. :laughing-smiley-014:
And Eddy, they weren't PK's they were flicks cocktails :)
Same diff :P
haha, I think you'll find (from what I've heard) that PK was the teacher & Flick is now a well qualified student :)
Im way to lazy, so i'll give Tilbrook a call and see what he's upto these days, when he shut up shop he said he would still work on my car, and at a discounted rate :D
what happened with the turbo swap organized by Steve (at you know whose place)?
If you can get a decent price with a tune, I might be interested as well Chad........my back is still way too sore to be bending over all day otherwise I'd do them myself and I'd probably do yours and Luke Heslo's at the same time..........also, I'm over waiting for peeps to get back to me regardless of how busy they may be :(
fckn ROFL!
name="allowFullScreen" value="true"></param><embed src="
type="application/x-shockwave-flash" allowfullscreen="true" width="425" height="344"></embed></object>&">
type="application/x-shockwave-flash" allowfullscreen="true" width="425" height="344"></embed></object>&" type="application/x-shockwave-flash" wmode="transparent" width="425" height="350" />
haha Too right! Cocktails are my specialty tho. Pk's Specialty is unusual shots.. just ask him bout the shot containing tobasco sauce.. thought i was gonna die after that one!
Few people from here can testify that my cocktails at lukes last party were pretty good!
oh don't remind me, I'm still spewing I couldn't make it
    • Not sure the US can import anything other than the C34 Stagea's, but if you can and you need to to tow, DO NOT under any circumstances get an M35 Stagea. If it is just as a family car and your country/state allows it, absolutely and definitely get an M35 (3.5L if possible as it is effectively a 350Z) over a C34.
    • Punch your VIN (nm35-xxxxxx) into Amayama.com You can see everything there quite easily.
    • Thanks for that, I'll check it all out. I can always do the brakes last anyway if its a problem.  The 16's are super cool, if they do fit I'll cruise around with them for a bit.
    • Well, that's kinda the point. The calipers might interfere with the inside of the barrels 16" rims are only about 14" inside the barrels, which is ~350mm, and 334mm rotors only leave about 8mm outboard for the caliper before you get to 350, And.... that;s not gunna be enough. If the rims have a larger ID than that, you might sneak it in. I'd be putting a measuring stick inside the wheel and eyeballing the extra required for the caliper outboard of the rotor before committing to bolting it all on.
    • OK, so again it has been a bit of a break but it was around researching what had been done since I didn't have access to Neil's records and not everything is obvious without pulling stuff apart. Happily the guy who assembled the engine had kept reasonable records, so we now know the final spec is: Bottom end: Standard block and crank Ross 86.5mm forgies, 9:1 compression Spool forged rods Standard main bolts Oil pump Spool billet gears in standard housing Aeroflow extended and baffled sump Head Freshly rebuilt standard head with new 80lb valve springs Mild porting/port match Head oil feed restrictor VCT disabled Tighe 805C reground cams (255 duration, 8.93 lift)  Adjustable cam gears on inlet/exhaust Standard head bolts, gasket not confirmed but assumed MLS External 555cc Nismo injectors Z32 AFM Bosch 023 Intank fuel pump Garret 2871 (factory housings and manifold) Hypertune FFP plenum with standard throttle   Time to book in a trip to Unigroup
