well lucky it wasn't! but the car is black with some club sticker on the back and 19"+ chromies with a custom number plate! and plus his car was loud as a mofo
I would of just ignored the commo :) might of been an undercover... too risky... damn new commodores lol
yeh my mate in the gold CV8Z monaro said he saw every1 scatter...lol
i cracked up laughing when he told me n i thought 2 myself "i bet that was craig's organised cruise"
dob on u 4 wat?????????????????????
hey was it u that had a mate with a vxss??? was it gold??
na i dont have a mate with a vx ss, i have one with a worked vx berlina though, me and him where dead equal
everytime we had a go (on private road) even though i had mass wheelspin through 1st 2nd....
cant wait to see your car on the road again man, it porn!
yeah sorry about that Carl............you should see me on a bad day :D
hahaha, its all good, 99% of the time its water off a ducks back with angry ppl. in my last role i was a TL for 13 engineers that work with secure coms (VPN's and hardware firewalls)... all i used to deal with was escalations, so i have a really good grounding in conflict resolution.
one thing that always gets me on the front foot is when someone that starts a conversation/query with "listen...", i find that quite rude. (this is not meant to offend but i find 99% of the ppl that say this are of a common nationality/background)
Bezender.. Get in to a company where you can work your way up and get away from being a CSO.
Internode is a good example. Admittedly you may take a pay cut from telstra/optus for the first couple of years but after 1year 2 absolutely max if your your not all that keen and your up and away from front line support.
i have put my resume in to move to there and take a $18k paycut... the money does not phase me, i'd rather have satisfaction. gotta keep slogging away with my mcse and ccna in the mean time
^ hey Ryan you/your place of business can retune stock ecus yeah?
My car is out of tune since I swapped the exhaust and wondering what sort of rough price I'd be looking at to get it touched up. It has already had all the stuff put in to be able to tune, so should hopefully only need a few hours to rectify a/f ratios, it's fking eating fuel big time at the mo :rofl:
    • I certainly fall into the annoyed camp, but glad to hear that if it's happening at low boost then I'm not likely going to blow a turbo and end up with metal shards in my oil. Just feels like it prevents me from really driving it without hesitation and "peak" performance. Wonder if it's the VCAM, it did an impressive job of shifting the torque curve and faster spool, but maybe now it's "too fast" and there's too much air for how open the throttle is.  Based on some other threads, will also do some reading on synchronizing the actuators. They are the default actuators that come on the Garrett's and I would think they would be set the same coming from the factory, but if the turbos don't actually work exactly the same way at the same time as previously mentioned, it would be worth making sure the actuators are actuating together properly
    • I went down this rabbit hole before, ended up sourcing a motor from the UK (I'm in Japan) which also didn't function correctly. With the original motor, I disassembled it and reassembled it and it works somewhat, sometimes. What I could deduce from all my screwing around is that there is calibration of the gears on the inside of the motor and two ramps on the main gear which activate switches that operate the motor and move the sunroof either to retract into the roof or tilt. Where I got stuck was that, it seemed in my case that one or both of the switches that are activated by the ramp on the gear did not always activate and thus the motor did not move, causing it to sometimes not retract or tilt (apologies, I've forgotten which way it didn't work.).  Of course this part is discontinued at Nissan now, it's the same part in the S15 but no other models. I also contacted the manufacturer of the component for schematics - forgot the name, they're based in Gifu - but they declined to share the information due to being bound by an NDA, sadly. Looking through my pictures now, it seems I last had a crack at this in 2022. See, I so kindly wrote "open" and "close" next to the switches. If you figure it out, please do tell me. Those little switches, with the red buttons may need to be replaced.
    • It says 300ZX, does that make it an Aus delivered car? Funny how back in the day I just couldn't care less about Z32's and these days I am just in love with them. Back when Nissan was into pushing the envelope. 🤣
    • Hi guys, just after some guidance with an R34 sunroof that has stopped working correctly. It still opens and closes perfectly fine, but it no longer tilts/vents up or down. As a result, the rear of the glass now sags a bit as it drops down slightly in order to retract into the roof, but now it can't pop upwards into a flush position. I’ve probed the pins on the back of the switch connector with a multimeter and it seems like both switches (for open/close and tilt/vent) still work correctly. Any ideas on what it could be, or where I should even start in terms of diagnosing? I'm sure someone's had this issue before but I haven't been able to find anything online relating to this specific issue, most of the issues are with the seals leaking or the motor failing entirely. Thanks in advance!
