Cilmi looked half pissed when she was speaking!! Either that, or she should stick to singing and give up speaking in public.
Veronica's look like 2 Amy Whinehouses. They both looked drug f***ed and I think it's safe to say, Australia is over their Kissing pose and them 2 holding hands.
Yeah, Faker is pretty bad. The lead singer acts like he's on some sort of medication.
Judging by the comments left on the News.com.au website in it's Aria's article, not many people even like the Aria's! Probably because it can't compare to the Grammy's or shows like that.
Pink sounded like she couldn't sing her own lyrics, leaving the backups to do it for her. She musta been paid by the words :)
Faker were not that great live.
and I don't care if Gab Cilmi can't talk ... she can sing and she's not bad looking. Just wish she was maybe 10 years older :P
Edited by RubyRS4
and how bad are Faker live?
Wait, how bad are faker all the time..
I didn't watch any of the ARIAs, but Faker were pretty damn good at Big Day Out this year .... but I was pretty smashed by that stage :D
Does the lead singer of Faker remind anyone else of Robert Smith of The Cure fame? Voice, mannerisms, reliance on alcohol/medication to dance ....
she looks the type that would be quite chunky in a few years unfortunately
Is Cilmi Italian or Greek?
definitely Italian
lol Andrew.......even I look good to you after a couple of beers, you & fishpaste even tried to kiss me after a couple of beers.........actually, I think Luke was totally sober at the time :)
Is it just me or is Amy Winehouse one of the ugliest famous people in the world? She has a face like a horse and thats being complimentary, ignoring the eyelash extensions that help her get airborne like a hand glider and the big hair covering a hot air balloon...
If I woke up and she was lying on my arm, I'd chew my own arm off. No shit. However the veronicas look ok when theyre not being anorexics
-D
-D
Have you ever seen black and white pics of Amy back before she was really drug f***ed? She actually looks really good.
Then again, black and white and decent photography can work wonders for anyone!!
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
    • Nah, that is hella wrong. If I do a simple linear between 150°C (0.407v) and 50°C (2.98v) I get the formula Temperature = -38.8651*voltage + 165.8181 It is perfectly correct at 50 and 150, but it is as much as 20° out in the region of 110°C, because the actual data is significantly non-linear there. It is no more than 4° out down at the lowest temperatures, but is is seriously shit almost everywhere. I cannot believe that the instruction is to do a 2 point linear fit. I would say the method I used previously would have to be better.
