Cilmi looked half pissed when she was speaking!! Either that, or she should stick to singing and give up speaking in public.
Veronica's look like 2 Amy Whinehouses. They both looked drug f***ed and I think it's safe to say, Australia is over their Kissing pose and them 2 holding hands.
Yeah, Faker is pretty bad. The lead singer acts like he's on some sort of medication.
Judging by the comments left on the News.com.au website in it's Aria's article, not many people even like the Aria's! Probably because it can't compare to the Grammy's or shows like that.
Pink sounded like she couldn't sing her own lyrics, leaving the backups to do it for her. She musta been paid by the words :)
Faker were not that great live.
and I don't care if Gab Cilmi can't talk ... she can sing and she's not bad looking. Just wish she was maybe 10 years older :P
Edited by RubyRS4
and how bad are Faker live?
Wait, how bad are faker all the time..
I didn't watch any of the ARIAs, but Faker were pretty damn good at Big Day Out this year .... but I was pretty smashed by that stage :D
Does the lead singer of Faker remind anyone else of Robert Smith of The Cure fame? Voice, mannerisms, reliance on alcohol/medication to dance ....
she looks the type that would be quite chunky in a few years unfortunately
Is Cilmi Italian or Greek?
definitely Italian
lol Andrew.......even I look good to you after a couple of beers, you & fishpaste even tried to kiss me after a couple of beers.........actually, I think Luke was totally sober at the time :)
Is it just me or is Amy Winehouse one of the ugliest famous people in the world? She has a face like a horse and thats being complimentary, ignoring the eyelash extensions that help her get airborne like a hand glider and the big hair covering a hot air balloon...
If I woke up and she was lying on my arm, I'd chew my own arm off. No shit. However the veronicas look ok when theyre not being anorexics
-D
-D
Have you ever seen black and white pics of Amy back before she was really drug f***ed? She actually looks really good.
Then again, black and white and decent photography can work wonders for anyone!!
    • I see what you mean on that last paragraph and makes sense. I am leaning towards because I made the repair/filler area large that I didn't use a long enough block. Will minimise the area and let you's know how I go. This is random but I noticed when I put epoxy primer it felt flat but that's just temporary.
    • Tried to repair with filler only. The block is a foam block but quite hard and I put a velcro on it for sandpaper, the hook and loop system. It's not one of those super soft ones that just follow the panel. Similar to a dura block.
    • You need one of those automated sprays that puffs a nice small every 15 minutes in their room. Except swap the nice smell for chloroform...
    • Don't step down power supply size, maintain it the whole way. It's how I'd do it. OR, Id have one feed, with one joint that splits out to six smaller gauge wires that go to each coil. I wouldn't add joins like stepping from 12 to 16, at the first two coils, as if you try to continue that fashion, each joint will introduce a voltage drop. In theory, earths should be the same size as power feeds, however in this case the main power needs to be bigger due to the average size current. So the next question is, how much current do these coils actually need?
    • I think Murray is onto it. It's sounding like either it's a soft block, not long enough block, OR if you're chasing waves, you're going in the direction of the waves, instead of across them. Rotate your sanding pattern by 45 degrees is something to try. You said you're going in an X, so now instead, from the same perspective, do a "t" instead.   If you're not able to have the block sit on top of two high points, and not touch the low point between them, you'll never get it flat.
