for sure Dan; you ignore just about any price you'd see on the piece of paper hanging in the window of a car at a car yard.
jeez i remember the price listed in the window of my white 33 (in my avatar) when i bought it from a yard back in the day... we knocked quite a sum of that price off compared to what i paid :)
guys need ya help palease :)
oka so went to go see my car today down at premier paint n panel n its finally coming together..yay..but a lil problem has occured..they have gotten my car to start and god does it sound good to finally here it again lol but now my hicas light is on and the steering is heavy as...ive had the hicas light on before but the steering wasnt affected..all i did was change the power steering fluid and it went away.
the guy said that had to disconnect some hoses around the power steering pump to do some work so im hoping that it just needs a top up of some fluid
would i be right??? or is it something else??
there hoping to have my car finished by this friday....cant wait :)
ur help will be appreciated.thanks
you will prob find that due to the car sitting around for so long, all the fluid has drained from the lines, and dried up.
give it another change, and see how you go :)
good to hear its nearly done...
This might not be the issue, but my Hicas light was on a while back and the steering was really heavy. It turned out to be a loose battery terminal (no bullshit). New terminal and the issue went away.
Check that, but more than likely it won't be that.
But check the power steering fluid and the hose connections.
Last night after work i decided to go to town on my dump pipes with a die grinder. Where the 2 pipes join together i ground out the hole to perfectly match the shape of the smaller pipe, spent about 1 hour on them as they are stainless so had to try and keep the metal cool. It should help to improve exhaust flow a fair bit :wacko:
hmm, how are b pillars stuck on? (The black plastic that is between the front and rear side windows) just glue?
On 33's theres a couple of lugs behind there, just pull the bottom out gently until it unclips (you may need a flathead) then lift it upwards. I've never tried doing it on a 34 so it might be different.
went and had my car remapped at turbo tune today and i gained 34 rwkw out of it
first run pulled 88.1 rwkw with a blocked fuel filter and fooked fuel pump..so replaced both of them and it pulled 111.2 rwkw
then after the remap it pulled 122.2rwkw..
im pretty happy with it considering the only mods are HD clutch, 2.5" full exhaust system with race cat and K&N panel filter
    • Lamb roast on Saturday will be different 🥲
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • I couldn't agree more. I should have started from the get-go with a NEO or solid bucket conversion. I started looking into converting over to solid lifters yesterday. Now for some reason I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  But I see no mention of this on any of the Tomei documentation. It just states that I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
