^^ Speak to Cubes, theres nothing he doesn't know about e85 :(
Struggling to work that one out. :S
I guess he feels that its going to be hotter, which will thin the oil out more :D
Edited by Damo_R34
well during summer time i drive long distances for fishing trips! i use valvoline 10/50 because the oil temp seems better and engine noise is quieter than when i use my normal oil nulon 10/40! could even be because of the brands i use but they're the only 2 i use
Edited by nos man
What were u doing? :(
Massive late reply :D
I work at the cas in Valet, some clown reckons I took money off them and pocketed it or something :D
Like I'm gonna risk my job for something stupid like that. Probably some kent just stirring the pot.
I like POETS Day..... Piss Off Early, Tomorrow's Saturday...
-D
lol, i like that one as well.
I shall be having one of those today; piss off early to the richmond and sink some brews with the work crew up on the balcony in the mall.
and damn its fine weather for it too!
on another note, i hear they are lighting up that Rundle lantern bizzo above Hungry jacks tonight
    • List all of your mods. It sounds like an aftermarket ECU hitting rev limiter. Like a valet mode, or a cold rpm limiter?
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
