pfft, just grab some $600 used s13 coilovers.
plus the rest for the s13 front end conversion, wont get much change out of 500 then
buy a good set of struts and get custom aurora springs like mine :devil:
for struts and aurora springs matty you dont do too bad hehe.
or i could just give you my budget and have you build it for me :D
i kno 31's like the back of my hand, DO IT!!!!!!!!
hmmm....
so your 31 will be up for sale soon?
well, it seems ryan is keen to help me atleast :P
he just wants a turn in it :D
trust me, you dont want mine
double defected, twisted, dented
only worth making a rolling shell out of to blow the living f**k outta at next years demolitions weekend
anyone got a busted RB30E they dont want?
Aww your selling it!! :P But you just got the Car trailer!! :D
You haven't ridden one yet have you? :ermm:
The engine (including the tuning) is brilliant! There is no snatchiness of the throttle whatsoever. It doesn't have mountains of power or mountains of torque, but what it does have it delivers smoothly and where the power should be. No jap bike I've ridden yet is as smooth as the F4 engines are. Thats the Ferrari influence there. The gearbox is brilliant also. Snips into gear easily, even under hard acceleration and without clutching. I've found most jap boxes clunky. Clutch feel is precise and smooth and easy to measure when powering off hard. Don't be fooled by the race for big power in bikes ... look closely at the delivery of that power to the rear rubber. Big power means nothing, if it is a pig to ride and if it upsets the handling of the bike. Even the newer jap hyper machines still are not smooth to ride. The MV is so smooth that abusing it will not upset its stability.
Oh ... and no other bike has that 'flutter' note to the exhaust like the MV :down: But in the end, she's the flirt, not the whore.
my mate let me ride his new 1100 Duc and what surprised me on this 175kg lightweight wasn't the power as such (although it will pop your eyes out) but the brakes :P:D
woo got my exhaust raised today, doesnt scape all the time going into the driveway now. Also found out the exhaust rattle i got is my mid muffler from hitting heaps of stuff, has broken a weld inside it and now rattles when cold or driving slow. $100
Paid for some Splitfires also today $615 del :D damm yen rate.
Also paid rego :P $693
total spent today $1408
haha do what i did to my old vs commy i sprayed sum WD-40 on them didnt sqeak for like a month but they didnt work as good, awww well hated everyone looking at me at the lights after the SQEEEEEEAK lol felt like brian in fast and the furious when he over shoots the drag line lol
Edited by r33 chris
    • Actually, that's not entirely true. It's also the same motor in the 1st gen Nissan Cube but they're rare as hen's teeth.
    • Yeah it is always worth testing and balancing actuators out of the box, just set the pressure regulator on a compressor very low (eg 5 psi) and increase it slowly to see when they both move.....unfortunately while you may be able to adjust the length of the actuator rod to minimise any difference, the actual pressure they move from is not adjustable so you need a well matched pair. And yes, the VCAM is probably contributing; the earlier in the rev range they come on boost and the slower the revs build (I think your demo was in 5th), the more you notice it.  Driving at WOT through 1st, 2nd, 3rd etc you will probably never hear it as any shuffling starts and is over super quickly
    • oh they were with that motor, you need to remove the engine to change the spark plugs (don't have to, but it does make it easier)
    • I certainly fall into the annoyed camp, but glad to hear that if it's happening at low boost then I'm not likely going to blow a turbo and end up with metal shards in my oil. Just feels like it prevents me from really driving it without hesitation and "peak" performance. Wonder if it's the VCAM, it did an impressive job of shifting the torque curve and faster spool, but maybe now it's "too fast" and there's too much air for how open the throttle is.  Based on some other threads, will also do some reading on synchronizing the actuators. They are the default actuators that come on the Garrett's and I would think they would be set the same coming from the factory, but if the turbos don't actually work exactly the same way at the same time as previously mentioned, it would be worth making sure the actuators are actuating together properly
    • I went down this rabbit hole before, ended up sourcing a motor from the UK (I'm in Japan) which also didn't function correctly. With the original motor, I disassembled it and reassembled it and it works somewhat, sometimes. What I could deduce from all my screwing around is that there is calibration of the gears on the inside of the motor and two ramps on the main gear which activate switches that operate the motor and move the sunroof either to retract into the roof or tilt. Where I got stuck was that, it seemed in my case that one or both of the switches that are activated by the ramp on the gear did not always activate and thus the motor did not move, causing it to sometimes not retract or tilt (apologies, I've forgotten which way it didn't work.).  Of course this part is discontinued at Nissan now, it's the same part in the S15 but no other models. I also contacted the manufacturer of the component for schematics - forgot the name, they're based in Gifu - but they declined to share the information due to being bound by an NDA, sadly. Looking through my pictures now, it seems I last had a crack at this in 2022. See, I so kindly wrote "open" and "close" next to the switches. If you figure it out, please do tell me. Those little switches, with the red buttons may need to be replaced.
