i couldve got you splitfires for 550 delivered...
You could have said that earlier ya cheeky bugger... Luke_ENR34 has been discussing obtaining splitfires in several threads over the last few weeks...
I would've been keen for a set too, although i just installed a set of supersparks an hour ago...
I'm running 6's in mine.....wondering if I should be running 7's instead now.
I've heard some peeps go even colder to an 8 or 9 even, but I assumed they got more track time
Once over ~270rwkw step up to the 7's. 350rwkw then I'd look at the 8's but then your in to easy plug fouling territory.
I run the BKR7E's, most places can only get the BKR7E-11's so grab them and gap them down.
I have no issues with plug fouling poor starting or plug fouling when cold.
The 6's were coming out looking a tad hot for the power its making; the 7's look perfect. :laugh:
I get around 30,000km's out of mine but thats really pushing them. They start to look worn at 20,000km's but don't seem too cause problems (hard starting and the odd pop) until 30k.
so ,
i was opening my door of my car and i saw something shoot past , went out on to the foot path and it was a koala , so i ran inside and grabbed my dslr and chased after him (was quite funny , a koala running up the street and me chasing it)
anyways he climbed into a small tree up the corner so i took about 50 photos of him and here is one of em
shot at 50mm 1.8
so ,
they are bloody angry things hey, ppl over seas come here and get attacked by them coz they think their good to hold on to for a while hahahaha :laugh: silly non aussies :P
Joel, on the topic of NKG plugs, can u get them pre-gapped to 0.8mm or do they only come in 1.1
All plugs for example.
BCPR6E or BKR7E are pregapped to 0.8mm.
They can be had from some stores but often need to be ordered in.
You can grab the BCPR6E-11 or BKR7E-11 which are pregapped to ..... 1.1mm and then gap them down :laugh:
I prefer to grab the 0.8mm pregapped plugs as the strap appears to be slightly shorter so the gap is more consistent even at 0.8mm to what the 1.1's are.
In saying that I haven't noticed any difference between 0.8 and 1.1's gapped down to 0.8mm. Currently I'm running BKR7E-11 gapped down to 0.8mm's.
cheers Joel,
i have a pile of BCPR6E-11 sitting here on my desk. i know what you mean about the long strap... i'll gap em down and get em in my car this weekend (my plugs are pretty foul).
i'll just continue getting these instead of looking for pre-gapped ones
cheers for that
so I'm currently running the iridiums BCPR6EIX-11 at .8mm......to run 7's, do I have to run BKR's or do they make BCP's.......what's the difference?
cheers for that
wasn't asking the difference between coppers & iridiums.....the suffix "IX" denotes iridium.
I wanted to know why Cubes uses a different prefix when going colder in plugs.
looking at the NGK site it makes me think they suit different models?!
    • Yeah in that case, pulling the dent out. Event a very slight dent can create a lot of work filler-wise and there is a strong chance the panel won't be the factory shape when you are done (as the dent will result in a new high point created somewhere, then everything is brought up to that new high point... but the panel shouldn't be that high if that makes sense).  So you've filled and primed the panel and it is flat, why would you go back and remove the primer and add more filler?
    • Something else I have been faffing with while the car was off the road is making the AC work. Assuming the car isn't at a thermal limit the idea of having AC while waiting in line to go on track sounds delightful. I have actually been lugging around the weight of the entire system since 2018 when the RB25NEO went in without it working at all.  The main reason was in the first few events before I got around to re-gassing it the rubber hose that runs under the manifold had the factory heat wrap/sleeve fail resulting in this: ~2 years ago I purchased a complete used R32 AC line set but when I finally went to install it the line i needed was different where the expansion section is I found a local place that was able to replace the rubber section and re-crimp. They also added some modern heat sleeve to the hose Tight fit but fingers crossed this is the last physical piece of the puzzle needed
    • the top black section is bonded to the silver section with some form of rubber. I assume to isolated NVH from the box
    • Plan B? Get someone to machine up a metal bush/collar/whatever it needs to be to replace the rubber? I haven't had a close look at that part recently to have a proper feel for whether that's possible. But it might be easy.
    • I do not want to install a short shifter and the only other stock throw shifter I have seen is the Nismo "Rigid shifter" for $290 So plan A is to fill it with sikaflex to stiffen it up and hope for the best
