R33 tank is 65Lt its my understanding that once the fuel light comes on there is 15lt left in the bottom of the tank it may be 8lt i cant remember, i know i read it in my manual though
Very nice. That means I had 14L left and did 478KM including some spiritedly driving! Thats pretty damn good economy :D I was freaking out thinking the cars going to conk out somewhere in the hills haha
so, in perth at the moment. went to the air race today, was fairly awesome aside from the long amounts of nothing in between shit. and goddamn perth has some pretty harsh sun, im pretty burnt up, lol.
^ so you did decide to piss off for a bit with that car money Dave. I got booted from the cas :D
got my new rims...
lenso D1R...
18x10+22 and 18x9 +15
hmmm lets say anyone keen for some mexican?
They doon't look too bad fitment wise. Is that with the suspension compressed? Even if it is, you could probaby get away with some nice tyre stretch and a bit of camber. If the suspension is hanging in those pics, I dare say the camber from loading it up + a stretched tyre will have those fitting fking brilliantly.
Either way a guard roll will be needed though :)
Haha thanks guys.
Nah he didn't wash it down with a Paley - but he is always trying to get his lips around a beer. Like father, like son I suppose.
Let me tell you though - after he finally came down from his sugar high he slept like a log last night :D
went on the Nissan Silvia Just Drive cruise, and had this happened to my mate (i was the passenger)...
As I was leaving the car park I was following the black 34 who decided to chuck a massive skid, cuttin a blind corner on fifteenth st, then he snapped it back sidewayz around the corner, spun out and was millimeters from hittin a stoby pole. Then he pulled another massive skid and drove off so i followed him thinking that he was goin on the cruise. After 3 minutes or so of following the dude i realised that he wasnt goin on the cruise. At this point i was lost, so i pulled over to have a look at the map and i realised that we were goin in the opposite direction to everyone else. So i turned around and tried to find my way back and got lost again. I cant bloody believe it! I was so frustrated that I ended up goin home.
just wondering who this hero is as he had an SAU sticker...
you know its ppl like that thats giving the rest of us a bad name...
THIS IS EXTREME!
FULLY BODY TATTOO
You thing you're tough and can handle tattooing? :)
Scroll down if you're not squeamish!
:):D:(
Edited by RubyRS4
hey guys just need to vent a little
my boyfriend Dante of 2 weeks went away for "work" without telling me he was going, and then i find out that while we were together he took some chick out off face book to lunch then after 3 days of not talking to me cause of "bad reception" he sends me a sms breaking up with me because lachlan is a big problem. when i got home yesterday there was a really nice email saying i need to get super model looks and loose weight so i can wear the bikini he has picked out for me and clames we were still together, so this is what i find today on his face book
Christie Hales-Thornton wrote at 7:12pmHey Sexy Boy, big THANK-YOU for the lovely lunch in Naracoorte. I'm in Adelaide next week, can't wait to catch up for coffee.
XOXO
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
