Hahahaha!
I may have to give my mate a heads up, he just got a Rx7 twin turbs. Id hate to see it with a big ugly sticker on it.
Luckily for me my 34 is about as high as a monster truck and doesnt attract much police attention.
Edited by ontheranch
What's the entry charge?
Depends on how much of the "chainsaw massacre" and pool install I get done on the weekend. Cramming everything into this weekend, so next weekend I can either trackday or SAU paintball.
Plus its the lads birthday on sunday and a riding buddies birthday on Saturday night ... things to do, things to do!
Edited by RubyRS4
sorry guys but i really need help and advice on this idiot of an x who wont leave me alone this is what i just received via email :(
"you going out for either a ride or lunch or anything with male friends ( married or not ) makes you a broad minded female."
why wont he leave me alone!
i just posted it and it changed the word it said s*ut
Edited by Bunny33
Is this the wank who broke up with you via sms?! And he's got the nerve to still e-mail you?!?!
Any guy who wants to attempt to control any woman from seeing their mates is just pathetic. Beyond pathetic. The item that guy is missing is Trust (amongst other things)!! Just because you're going out to lunch with a guy you're mates with, and have been for the past x amount of years doesn't mean you want to jump into his pants!
It's ridiculous, but there's so many guys who want to control their partner. It's jealously and a lack of trust. It's like him saying "I don't want you working there anymore because you work with MEN!! And if you're in the same room as another man, I count that as cheating!!"
The guys a knob.
The guys a knob.
yes this is the one but then he recons that he didnt break up with me grrrrrrrrrrrr i showed ben (grim) the sms and he said the same thing
hrmmm... so having a coffee with a friend makes you a broad minded female? yet, he can be seeing 2 people at the same time and thats okay????? =\
probably a good thing hes out of your life
Edited by Fishpaste~
    • Not sure the US can import anything other than the C34 Stagea's, but if you can and you need to to tow, DO NOT under any circumstances get an M35 Stagea. If it is just as a family car and your country/state allows it, absolutely and definitely get an M35 (3.5L if possible as it is effectively a 350Z) over a C34.
    • Punch your VIN (nm35-xxxxxx) into Amayama.com You can see everything there quite easily.
    • Thanks for that, I'll check it all out. I can always do the brakes last anyway if its a problem.  The 16's are super cool, if they do fit I'll cruise around with them for a bit.
    • Well, that's kinda the point. The calipers might interfere with the inside of the barrels 16" rims are only about 14" inside the barrels, which is ~350mm, and 334mm rotors only leave about 8mm outboard for the caliper before you get to 350, And.... that;s not gunna be enough. If the rims have a larger ID than that, you might sneak it in. I'd be putting a measuring stick inside the wheel and eyeballing the extra required for the caliper outboard of the rotor before committing to bolting it all on.
    • OK, so again it has been a bit of a break but it was around researching what had been done since I didn't have access to Neil's records and not everything is obvious without pulling stuff apart. Happily the guy who assembled the engine had kept reasonable records, so we now know the final spec is: Bottom end: Standard block and crank Ross 86.5mm forgies, 9:1 compression Spool forged rods Standard main bolts Oil pump Spool billet gears in standard housing Aeroflow extended and baffled sump Head Freshly rebuilt standard head with new 80lb valve springs Mild porting/port match Head oil feed restrictor VCT disabled Tighe 805C reground cams (255 duration, 8.93 lift)  Adjustable cam gears on inlet/exhaust Standard head bolts, gasket not confirmed but assumed MLS External 555cc Nismo injectors Z32 AFM Bosch 023 Intank fuel pump Garret 2871 (factory housings and manifold) Hypertune FFP plenum with standard throttle   Time to book in a trip to Unigroup
