thanks guys ... yeah I like the setup - it is what I have been wanting to do for a while now. The price of the 2433BW has recently fallen, plus they have a $50 cash back deal, so now was the time. Can't describe how much I am loving the Samsung - such a crisp, clear picture .... makes the AOC (it is an entry level monitor) look pretty ordinary.
Glad someone noticed/appreciated my CS guys Kietz - I think they are awesome. Of course, they are from 1.5 days with various costumes and camo gear. Hey the laptop kicks ass too - thanks mate! And oh yeah, how did you get such a slamming gf? :cheers:
ahahah its the SKYLINE!!! lol =P she just left to vietnam for 3 months this morning... so sad lol
nice setup Andrew ;:
i used to have 2 x 21" crts, they were awesome, could could take res higher than my 8800GT can put out.
i recently got these 22" flatrons, the colour is pretty damn nice and they have 10000:1 contrast ratio and 2ms refresh rate got em both for $400 :cheers:
wish my dad would have fking payed the phone bill
so now i have 2 phones , one pre paid one post paid
pre paid has no credit , post paid is blocked
now i have no fking way to call anyone , and all im getting
is sms's that i cant reply to
/ENDRANT
Andrew & Carl, your desks are too clean, lol................don't you guys do any work.
I'm too embarrassed to show mine, there's paper work & CD's everywhere at the moment
+1
no way hozey
i love your new sig there Brendan :blink:
Chris when cutting and polishing your headlights its only a every so light touch you use if you press hard it will scratch up the plastic
i read Sambo sprayed clear coat over his after preparing them with wet rub paper and there awesome
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
